Go to Post Ah, to be a teenager and know everything again. - Alan Anderson [more]
Unread 12-01-2008, 12:59
MrForbes MrForbes is offline
Re: pic: Pulley?
It might help to know how big it is supposed to be, and what the requirements for it are...for example, does it need to be a specific width, or could be anywhere from 2" to 6" wide? does it need to have a specific diameter inside for the shaft, and outside for the cable/wire/whatever to roll onto? Is there some weight limit you have in mind? Do you have welding capability, or a shop in town that could weld steel or aluminum, if you could cut a tube and make the "washers" for the ends? and is there some other way to attach it to a shaft?
pic: Team 48 Drive Pulley A_Reed Extra Discussion 2 29-01-2007 12:26
Large CIM motor pulley size/series? Tim Skloss Technical Discussion 3 09-01-2007 22:36
big CIM pulley Rickertsen2 Motors 1 18-01-2006 11:41
Timing Belt and Pulley Joe_Widen Technical Discussion 4 16-01-2006 13:41
Gear and Timing Pulley Design Resources Madison Technical Discussion 2 08-05-2003 21:01
