Go to Post a robot that is broken shows that it has survived more than a robot that doesn't even have a scratch. - robot180 [more]
Unread 12-01-2008, 17:05
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: Pulley?
Aside from making it from 3 pieces (use 3 long screws and nuts to hold the ends together), or having Kevin's team make one up for you (Note that "Priority Mail" from the post office has a flat rate box, send anything that fits in the box for just under $9. Even lead plates.), you can find Electrical Wire on spools like this. Go look at Radio Shack to see small versions of what I mean, an electrical supply house (or Home Depot/Lowes/hardware store/etc) will have them in a variety of sizes, and once they sell the wire off a spool they usually throw it away. Or if a parent is an electrician.
Good luck,
Don
pic: Team 48 Drive Pulley A_Reed Extra Discussion 2 29-01-2007 12:26
Large CIM motor pulley size/series? Tim Skloss Technical Discussion 3 09-01-2007 22:36
big CIM pulley Rickertsen2 Motors 1 18-01-2006 11:41
Timing Belt and Pulley Joe_Widen Technical Discussion 4 16-01-2006 13:41
Gear and Timing Pulley Design Resources Madison Technical Discussion 2 08-05-2003 21:01
