Go to Post Are quadcopter rotors considered a pneumatic device? - bobbysq [more]
Unread 12-01-2008, 22:00
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: pic: 1458 Manipulator prototype1
Originally Posted by abeD View Post
If the belt is pushing down hard enough it doesn't look like it will come loose, I like this design nice job on the prototype. What kind of reduction/rpm is the belt running at?
Its a CIM running at a speed reduction of 2:1, we could put a higher ratio on it, but even at this low ration it is able to do everything we ask of it.
Cool! Looks like you guys are doing great this year!
We prototyped a design just like this on day 2 and it seemed to work well. However, I think you'll find that unless you are planning to build a very low drivetrain you may not be able to get the forks under the ball. A lower roller might be necessary...
Thank you, we are further ahead of schedule this year then last, hopefully if you pick us again we will be more of a help . We have the bottom fork further behind then the top rollers, approximately 10". This allows the ball to come in contact with the rollers before the bottom forks. We haven't designed our drivetrain yet because This is our leading design, so if we select this design our base will be radically different. (probably a foot shorter then limit, and an open front)
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
pic: 1458 teaser Woody1458 Extra Discussion 15 11-01-2008 13:04
pic: Team 418's Manipulator Henry_Mareck Extra Discussion 3 04-04-2007 20:19
pic: 1529 Lollipop Manipulator Taylor Robot Showcase 7 26-02-2007 18:32
pic: 121 Manipulator Prototype Joe Menassa Extra Discussion 8 09-02-2007 06:13
pic: 1458, 22 and 1097 CJO Extra Discussion 1 31-03-2005 12:58
