Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 13-01-2008, 15:00
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: pic: The real robot - Week One work
Thanks for the many suggestions. By far the coolest thing that we have found with a week's worth of play with this urethane belting is that no tensioning system is needed at all. The elasticity and friction between the belt and the UHMW pulley is terrific. Even when the belt looks slack, it grips the pulley and does not slip. We'll look at the side load issue and may go to the two belts from the drive shaft going to a single wheel as a fail safe idea. Since the belt is under constant tension, is that making the side loads more of an issue then in previous years when we ran the Kitbot and transmissions in very much the same configuration with ansi #35 rollerchain?
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pic: Our ALMOST COMPLETED ROBOT!!! REAL PICS!!!! L@@K!!! sgsdragons Robot Showcase 13 19-02-2005 14:22
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: Here is the real robot from Team 1313! CD47-Bot Extra Discussion 6 04-03-2003 12:45
Which one is the real Dean? archiver 2001 0 24-06-2002 02:36
6 WEEK CRUNCH TIME = ENOUGH REAL WORLD DEAN-O!!!!!!!!!!!!!!! archiver 2001 33 23-06-2002 22:32
