Go to Post Clearly they're releasing the game hint on 12/21/12 because they know the world's going to end, and they want to keep FIRSTers happy and distracted until the very end. - Kevin Sevcik [more]
Unread 13-01-2008, 17:58
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Re: paper: Xbox map file
I hope this controller map helps at least a couple of people . I'm not 100% sure this works fully yet because we have yet to receive our chicklet but, if the mapping is the same as the computer, this should work. It'd be much appreciated if you guys could give me input as to how well you find this works and if there are any errors, thanks!
How to use the data obtain in one C file to another C file? tommy_chai Programming 8 11-01-2008 02:17
"Error.MCP" file after HEX file trans iwdu15 Programming 1 24-01-2007 20:05
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
