Go to Post I wonder if the GDC had his extraordinary achievements in mind for the 2012 game. - MagiChau [more]
Unread 15-01-2008, 12:45
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: pic: Team 223 Chassis
Wow... cut them some slack.
I'm sure a team that's been around that long knows what CG is, and I bet that's only 50-60 pounds of what's going on the robot, you don't know how the rest is distributed. For all you know that could be all 1/16" wall and be much lighter than you are guessing.
114 of all people should know that being tall doesn't necessarily mean poor CG.
Tall doesn't mean high CG, no.
However, tall & offcenter does mean unfavorable CG, typically.
Lets say that there is 60lbs there. Add in the chassis weight, lets say 15lbs, evenly distributed, and the rest of the 120lbs (putting 45lbs) on the other side. Divide that 15lbs for chassis by two and you get 67.5 (woo hoo) lbs on one side and 52.5lbs on the other side. Add in the height, and it gets pretty bad. Then add in the dimensions and it multiplies the problem.
And that's in the best-case, from what I can see.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
pic: Team 1058 chassis PVCMike Extra Discussion 3 30-01-2007 22:28
pic: Team 1058 chassis II PVCMike Extra Discussion 10 29-01-2007 23:53
Hats off to team 223 M. Hicken Thanks and/or Congrats 1 08-03-2004 17:42
pic: Team 27 2004 Chassis CD47-Bot Robot Showcase 2 25-02-2004 23:29
pic: Team 369 Chassis CD47-Bot Robot Showcase 7 11-02-2004 19:58
