Go to Post WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Katie_UPS [more]
Unread 15-01-2008, 12:50
Re: pic: Team 223 Chassis
Originally Posted by Otaku View Post
Tall doesn't mean high CG, no.
However, tall & offcenter does mean unfavorable CG, typically.
Lets say that there is 60lbs there. Add in the chassis weight, lets say 15lbs, evenly distributed, and the rest of the 120lbs (putting 45lbs) on the other side. Divide that 15lbs for chassis by two and you get 67.5 (woo hoo) lbs on one side and 52.5lbs on the other side. Add in the height, and it gets pretty bad. Then add in the dimensions and it multiplies the problem.
And that's in the best-case, from what I can see.
I stand by my original statements. I highly doubt that 45 pounds is in that structure.
Considering that 1" square 1/16" wall is only .28 pounds per foot, I highly doubt there is any more than 10 pounds (and that's overestimating) in that structure.
As for it being off center, we have no idea what the rest of the robot is. It could have an arm that extends the other way and brings the CG perfectly in to balance.
And yes, not all old teams are capable, but a team capable of putting together a CAD that nice looking is most likely capable of setting material properties/weight and then going to view> Center of Gravity.
but then again, it's possible they used entirely heavy materials on the top while discovering some new amazingly light material to use on the base.
Until we get the details from 223, let's hold off on the immediate criticism shall we?
pic: Team 1058 chassis PVCMike Extra Discussion 3 30-01-2007 22:28
pic: Team 1058 chassis II PVCMike Extra Discussion 10 29-01-2007 23:53
Hats off to team 223 M. Hicken Thanks and/or Congrats 1 08-03-2004 17:42
pic: Team 27 2004 Chassis CD47-Bot Robot Showcase 2 25-02-2004 23:29
pic: Team 369 Chassis CD47-Bot Robot Showcase 7 11-02-2004 19:58
