Re: pic: 973 finished parts
Why couldn't that have been done that with manual equipment? Looks pretty simple. You could have just taken your zero at one end, machined the two holes, and then taken another zero at the other end and machined the other hole.
Thats how I machined our drivetrain.... It was actually longer than the mill! ![]() |
Actually if you took the zero at one end and then set the other end as your zero when done with the first side you are relying on the fact that your piece is to exact length, which in most cases is not too critical but if they are saying the tolerances are tight than you probably want to just indicate off a hole on the first side you did and work off of that...... Are these part of the frame?
They look like upright supports for a pivoting arm -- and in that case, you'd want the holes on opposite ends to be in the same position relative to one another, not the end of part. Everything is probably zeroed to the right side of the piece so that, when mounted on the robot, the pivot holes (leftmost in the image) align.
All of the holes are in tolerance to each other, and it is crucial to what and they way we are doing it to know that; If you are familiar with a certain team, and have seen our teaser, it is should be rather obvious
Yes, those holes are critical, and yes, I think they would run dimensions from the right side. |
Sigh. I dream of the day when our team is able to make parts that have the word "precision" in them! For now we have our trusty hack saw and drill. If the parts don't align keep drilling until they do! We try to account for a certain amount of "slop" in all of our designs
One day though....CAD...lathe...CNC....ahhh. |
| pic: 973 teaser #2 | AdamHeard | Extra Discussion | 10 | 11-01-2008 22:55 |
| pic: Possible 973 Teaser | AdamHeard | Extra Discussion | 18 | 11-01-2008 21:00 |
| pic: 254/968 Finished Parts | Cory | Extra Discussion | 9 | 08-01-2008 10:04 |
| pic: 968 - Plenty of finished parts! | Travis Covington | Extra Discussion | 5 | 01-02-2007 02:10 |
| pic: 968 - A few finished parts! | Travis Covington | Extra Discussion | 26 | 24-01-2007 08:02 |
