Go to Post IRI: where egos go to die...uhm..I mean fly! - Koko Ed [more]
Unread 16-01-2008, 18:42
jjjeski jjjeski is offline
FRC #0223
jjjeski will become famous soon enough
pic: Wheelie Bar
Unread 16-01-2008, 18:44
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Re: pic: Wheelie Bar
dude... You are my hero. That is the most ingenious Idea I have seen in a long time. Way to KIS guys. Nice.
Now, how big are those casters? and is that thing pneumatically pushed out?
wow, Vivek
Unread 16-01-2008, 18:51
MochaBear MochaBear is offline
AKA: Janak Das
FRC #0219 (Team Impact)
MochaBear is an unknown quantity at this point
vivek is right, they should be motor or pneumatically driven out otherwise it will be outside the foot print at the start of the round
Unread 16-01-2008, 19:23
wmatt2014 wmatt2014 is offline
AKA: Matt
FRC #2374 (CrusaderBots)
wmatt2014 is an unknown quantity at this point
what wheels are you using it looks like you are using two standard/traction and one omni per side. being a six wheel drive, are you going to use a rocker style? looks cool though
Unread 16-01-2008, 21:08
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Our rookie bot had a similar outrigger system. We mounted hinges on the back of some metal screen enclosure post material and started the match with the outriggers upright, roughly vertical. At the start of the match, we would shake the robot and gravity would bring down the outriggers which landed on a cable that pulled a pin on a spring loaded rod, which shot out above the outriggers, locking them down.
It sounds a lot more complicated than it really was, and it didn't require any extra pnumatics or motors.
Unread 16-01-2008, 21:19
Zyik Zyik is offline
Observer
Zyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond repute
Will it violate R16?
Unread 17-01-2008, 11:21
Deep Dark's Avatar
Deep Dark Deep Dark is offline
AKA: Dave Woods
FRC #2506 (Saber Robotics)
Deep Dark is on a distinguished road
Send a message via AIM to Deep Dark
Our team, 2506, uses the same McMaster-Carr press fit aluminum framing system for our chassis and drive base. We also use the ribbed type extrusion from that series, in combination with the plain type. It works quite well, provided you mill the edges flat and make sure all the dimensions are correct before you assemble. taking them apart can be a pain, but is do-able.
537 (the team i was for my first 5 years of FIRST) used it in 2007 for their chassis as well. It held up fine in competition. To make sure, they added pop-rivets at each connection point to ensure the press-fit plastic & steel connectors wouldnt come out.
Highly recommended stuff as far as i'm concerned. It leaves a clean finish, and it's light comparatively.
Dave Woods
Mechanical Engineer - Rexnord Conveying Equipment (New Product Development)
Alumni - Milwaukee School of Engineering (W-11
May '07 - present: Mentor/Co-Lead - F.R.C. Team 2506 Saber Robotics
May '06 - May '07: Mentor - F.R.C. Team 537 Charger Robotics
May '02 - May '06: Student - F.R.C. Team 537 Charger Robotics
Unread 17-01-2008, 11:55
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
A brilliantly simple solution to a possibly paralyzing problem.
This kind of stuff is great. Rather than overthinking and overengineering to solve the problem, you add a few casters and some bars. Problem solved.
God I love FIRST.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 17-01-2008, 12:00
MrForbes MrForbes is online now
Good to see you are thinking about the comments from your last picture! I wonder where that one came from?
and as mentioned, make sure it still fits the 80" rule....
Unread 17-01-2008, 12:42
R3P0's Avatar
R3P0 R3P0 is offline
Always InTeNsE!
AKA: Jamie Robinson
FRC #1504 (Desperate Penguins)
R3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of light
Send a message via ICQ to R3P0 Send a message via AIM to R3P0 Send a message via Yahoo to R3P0
I'd like to know what this press fit stuff is. I couldn't find it under press-fit alunimium.
How about a part number so we can check this stuff out? Or is it the same as Faztek/80-20 extrusion stuff?
Thanks
R3P0
Time is irrelevant at the speed of light.
Unread 17-01-2008, 13:38
xcarmichael65x xcarmichael65x is offline
william carmichael
AKA: carmichael
FRC #0065
xcarmichael65x is an unknown quantity at this point
warning!!!!
wheelie Bars are always nice to help stop flipping
but
if another robot gets stuck or damaged because of them
you might be penalized
take it from me
its happened to us
huskie brigade team 65
07 senior
08 mentor
GLR - Picked By 8th Seed, Knocked out 1st Round (4-4)
Buckeye - Picked 8th Seed, Knocked out 1st round ( But only team to defeat #1 Seed) (5-3)
Championships - 8th Seed (Picked 503,79), Finalist On Galileo. (6-1)
2007 FRC Record - 19-11-0
pic: 4 robots on the bar CD47-Bot Extra Discussion 11 21-03-2004 10:55
pic: 4 on the bar CD47-Bot Extra Discussion 4 18-03-2004 10:32
pic: Hanging on the bar CD47-Bot Robot Showcase 4 25-02-2004 22:29
SwampThing wheelie-bars at UCF Tytus Gerrish Regional Competitions 0 14-10-2003 22:54
pic: Under the bar CD47-Bot Extra Discussion 2 16-03-2003 22:38
