#11
Re: pic: 2200 Finished the Main wiring!!
Interesting. You seem to have divided the Rockwell block into two sections. I don't think there's anything wrong with that, but I'm curious why you made that design decision. Did you get an extra grey end-block for the far end (which is out of the shot) so that you don't have to worry about the black blocks sliding?
I'm assuming your master breaker is also at the far end there. Are you sure you will have enough room to get the serial cables in and out of the robot controller once this is mounted on/in your chassis? Plugging them straight in needs about 3.5" of clearance, as I recall (although there is the option of right-angle serial adaptors to get you out of that problem). Where does your backup battery sit? You've got a fairly clean wiring job there. It looks very nice. ![]() |
| Team 2200 Year in Review 2007 | Bochek | Robot Showcase | 0 | 13-01-2008 22:09 |
| the main code | Roni2230 | Programming | 9 | 10-01-2008 12:14 |
| pic: Main drive mount | falconmaster | Extra Discussion | 2 | 18-01-2006 20:05 |
| pic: Posing on the finished goal | BigPapa | Extra Discussion | 0 | 10-01-2006 16:59 |
| pic: Wiring Up the Bus (team 180) | CD47-Bot | Extra Discussion | 1 | 05-04-2004 01:40 |
