Go to Post That inspector needs their hard drive wiped and the common sense upgraded from version dingbat 1.0. - Andy Baker [more]
Unread 18-01-2008, 13:17
Matth3w's Avatar
Matth3w Matth3w is offline
mh3w from yspilots :)
AKA: Matthew Winfield
FRC #2432 (Spartans)
Matth3w is on a distinguished road
Send a message via MSN to Matth3w
pic: Wiring
Unread 18-01-2008, 13:19
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
Re: pic: Wiring
I would probably avoid wood for a base unless you have something under each component, I think we used plexy. We had screwed a bunch of stuff onto wood to make a test board to mess around with, and after awhile it started to smoke.
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
Unread 18-01-2008, 13:21
EricH EricH is offline
Re: pic: Wiring
Wood is fine, as long as you don't try to run current through it. 330 has used wood for I don't know how long (5 years minimum) without an issue. We even hogged out the base last year and it held up to everything we could throw at it.
Unread 18-01-2008, 22:15
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: Wiring
are the fans able to be wired like that?? that would save some trouble for sure!
Unread 18-01-2008, 22:16
Re: pic: Wiring
Far as I know, it isn't disallowed.
Unread 18-01-2008, 22:20
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
Re: pic: Wiring
Yeah, the wires are allowed. In its website if you see wiring it shows like that. And its so good to wire it like that. We did and there is no problem..
Also we are using wood board, we are driving it 1.5 week, so there is no problem with using wood.
Begüm
Unread 18-01-2008, 22:21
in between teams
AKA: Luke Van Oort
Re: pic: Wiring
While I have had an inspector get on our case about wiring fans to the Victor inputs, that was only one guy and I have doubts about his competence. The IFI user's guide to the Victor says to wire it this way, so that's how we usually do it.
Team 1219: 2009 - Mentor
pic: Cart Wiring Plans BlackShadowFox Extra Discussion 31 30-10-2007 15:32
pic: Wiring Nightmares Pjohn1959 Extra Discussion 7 07-02-2007 18:15
pic: cat5e Camera wiring Chriszuma Extra Discussion 4 09-03-2006 23:16
pic: Team 125 wiring Emily Pease Robot Showcase 9 10-02-2005 10:59
pic: Complicated Wiring CD47-Bot Robot Showcase 4 11-03-2004 00:03
