Go to Post Don't short change your drivers. They really need drive time. - Joe Johnson [more]
Unread 19-01-2008, 00:51
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: pic: 2200 Finished the Main wiring!!
Originally Posted by Schnabel View Post
The only thing that I wonder about is why you guys choose metal as a base. I would be worried about wires coming uncrimped (/sp) and then shorting out on it.
The chassis is not grounded as per the rules, so it would take both a positive wire and a ground wire to both come loose and to both contact the metal to cause a problem.
Our wires are tied so tightly that this would be almost impossible anyways.
Originally Posted by vhcook View Post
Interesting. You seem to have divided the Rockwell block into two sections. I don't think there's anything wrong with that, but I'm curious why you made that design decision. Did you get an extra grey end-block for the far end (which is out of the shot) so that you don't have to worry about the black blocks sliding?
Yes, we have 4 end blocks.
Are you sure you will have enough room to get the serial cables in and out of the robot controller once this is mounted on/in your chassis? Plugging them straight in needs about 3.5" of clearance, as I recall (although there is the option of right-angle serial adaptors to get you out of that problem).
Where does your backup battery sit?
Yes we have allowed enough room for the cables. the robot extends 3 inches past the end of the plate.
The backup battery mounts to a bracket on the side near the rc.... not in this picture.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Team 2200 Year in Review 2007 Bochek Robot Showcase 0 13-01-2008 22:09
the main code Roni2230 Programming 9 10-01-2008 12:14
pic: Main drive mount falconmaster Extra Discussion 2 18-01-2006 20:05
pic: Posing on the finished goal BigPapa Extra Discussion 0 10-01-2006 16:59
pic: Wiring Up the Bus (team 180) CD47-Bot Extra Discussion 1 05-04-2004 01:40
