Go to Post PS: Please use the default font for postings, it is so much easier to read. - DonRotolo [more]
Unread 19-01-2008, 01:15
EricH EricH is offline
Re: pic: 2200 Finished the Main wiring!!
Originally Posted by beemgruem View Post
For my drive train don't I need 2 victors for just 2 CIMs? Am I wrong? Why would I need 4?? And we are having 1 for our lifting actuator.. So that shows three? I am just lost for 2 CIMs for 4??
And also it is a good idea to just replace it.. I think I will use it..
Rule of thumb: If it's a motor, it uses a Victor. If it's a piston (or a motor used like a piston), it uses a spike. So, two CIMs per side of the drive, that's four victors. I guess they have four motors for a hurdling device.
In your case, as described in this post, yes, you only need three. Add one per motor added later. (e.g. adding two CIMs to the drive takes your total to five.)
Team 2200 Year in Review 2007 Bochek Robot Showcase 0 13-01-2008 22:09
the main code Roni2230 Programming 9 10-01-2008 12:14
pic: Main drive mount falconmaster Extra Discussion 2 18-01-2006 20:05
pic: Posing on the finished goal BigPapa Extra Discussion 0 10-01-2006 16:59
pic: Wiring Up the Bus (team 180) CD47-Bot Extra Discussion 1 05-04-2004 01:40
