Go to Post we need a diverse team, and until we can welcome someone that's not a nerd, I don't think we're really successful in our recruiting. - JBotAlan [more]
Unread 18-01-2008, 12:35
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
pic: Anderson motor disconnects
Unread 18-01-2008, 12:36
Newzealand38 Newzealand38 is offline
AKA: Alex
FRC #2102 (Team Paradox)
Newzealand38 has a spectacular aura aboutNewzealand38 has a spectacular aura about
Send a message via AIM to Newzealand38 Send a message via Yahoo to Newzealand38
Exclamation Re: pic: Anderson motor disconnects
Where do you get the small Anderson connectors? we wants them!
Unread 18-01-2008, 12:39
in between teams
AKA: Luke Van Oort
The Robot Marketplace has them... we bought a bunch in 2006, but ended up not using them. Reportedly, the Poofs have had problems with the little Andersons; however, I haven't heard of anyone else having major issues. Personally I'd rather just use standard barrel disconnects. Easier to find, and there isn't any real functionality loss (well, you lose the ability to slide them together into blocks, but that is pretty much useless unless your make your electronics board removable like 842, 118, 116, and whoever else does it).
Team 1219: 2009 - Mentor
Unread 18-01-2008, 12:47
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
With the smaller andersons, they suffer from a few easily fixed problems-
Crimping the wire into the contact may not work. I've had a few pull out, including one right before a match. I ended up jamming the wire back in and taping it in place for that match. Fixed it for the next fight by crimping and soldering. A lighter crimp and a decent solder joint works better for them, anyway, as it won't warp the contact as much.
If you have problems with them coming apart, there are either these-
Blok-Lok PowerPole Clamp's for the 15, 30 and 45 amp powerpoles
The other, cheaper, easier solution is to wrap the connection between the two connectors in electrical tape. Not sure exactly how legal that is, but I don't see a reason it *should* be illegal.
Team 675-Alumni
Near Chaos Robotics
Unread 18-01-2008, 22:30
Hiteak's Avatar
Hiteak Hiteak is offline
Improving the Technology World
AKA: Dan Schneiderman
FRC #3157
Hiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond repute
Send a message via AIM to Hiteak
I used them on our electronics board last year and I really liked them. They were really useful to separate different systems and to trace my wiring. The only hard part we had was trying to figure out how to hook them up at first, but we figured it out pretty quickly.
RIT '13
Computer Science House Member
Working towards improving technology policy
Student: Team 1930, 2005-2008
Mentor: Team 2999, 2009
Ruckus: 2006 -2010
Volunteer:
NJR: 2008
FLR: 2009, 2010
Unread 19-01-2008, 03:41
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
I absolutely love the smaller Anderson powerpoles! Just remember the convention if you're looking into the connector: "Tongue down, hood up, red on left, black on right!"
And the gold fans? Did you guys take out the blades and paint them? Is that within the rules, or would that be modification of an electrical component? Either way, they do look cool
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Last edited by Richard McClellan : 19-01-2008 at 03:45. Reason: added second paragraph
Unread 19-01-2008, 03:52
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We had major issues with these in 2006. We had all our motors using Anderson quick disconnects, all properly installed, crimped, soldered, etc. We had intermittent contact issues on numerous occasions, even after totally replacing the crimps. Eventually we decided it wasn't worth the hassle, and went back to using standard connectors.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-01-2008, 14:01
MikeJ675's Avatar
Near Chaos Robotics
AKA: Mike Jeffries
It sounds like a silly question, but were the contacts fully inserted into the housing? If not, that could cause the contact issues you had as the contacts will not be in the right position and even able to pull out completely.
Team 675-Alumni
Near Chaos Robotics
Unread 19-01-2008, 14:48
DonRotolo's Avatar
Back to humble
FRC #0832
West Mountain Radio sells an excellent crimper for the PowerPole 15/30/45 amp series, worth it's weight in gold.
Don
Unread 19-01-2008, 16:51
Cory's Avatar
AKA: Cory McBride
Yes, they were.
2001-2004: Team 100
Unread 19-01-2008, 16:54
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
The powerpoles are a bit pricey for my liking. I think you're better off with the usual spade connectors.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 19-01-2008, 17:22
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
I've had to use pliers to many time to get the spade connectors apart. i use these when ever i can. and mcmaster has them.
Jason
Unread 19-01-2008, 21:55
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Cory-
I am not sure why you had problems with these. We have been using them for years. Provided we assemble them with some care, we have never had problems with them and they have been very reliable.
-dave
Unread 19-01-2008, 22:39
Cory's Avatar
AKA: Cory McBride
Originally Posted by dlavery View Post
Cory-
-dave
We aren't sure either. We never took the time after the season to pursue why they weren't working correctly for us. I'm sure if we did, they'd be fine.
I didn't mean to put anyone off to using them. Clearly others have had good experiences. Just to be very, very careful with how you assemble them.
2001-2004: Team 100
Unread 19-01-2008, 22:43
MrForbes MrForbes is offline
Something about my life experiences with vehicular electrical systems makes me think that putting a ring terminal on the end of the motor wires, crimped and soldered, would be the most reliable way to go. This requires designing the robot around this concept, though! like putting the Victors next to the motors, and fully accessible.
pic: mounted Anderson falconmaster Extra Discussion 14 19-01-2008 11:49
Anderson Powerpole Connectors Kmo Electrical 4 14-01-2008 00:33
Anderson Connectors!!!! cdennisxlx2 Electrical 9 06-03-2006 19:20
#6 Battery Quick Disconnects Mr.D Electrical 3 23-01-2006 11:36
Quick disconnects for electrical gail OCCRA 1 25-10-2003 16:10
