Go to Post So go out and learn something new, even if it is old. Co-operate in this and you'll get much more out of it. Cheat and you are only cheating yourself. - ChrisH [more]
Unread 19-01-2008, 10:12
MikeZ MikeZ is offline
FRC #0624 (CRyptonite)
MikeZ has a spectacular aura aboutMikeZ has a spectacular aura about
Re: pic: DeWalt carnage
Originally Posted by richardmcc2 View Post
We are doing the same thing This will be our first year using Dewalts on the competition robot, but I did personally assemble 4 CIM/Dewalts (DC980) for an off season project last year. We have 4 DC940's that should arrive Monday, but I was hoping to get a head start on making some of the parts (top hat, servo plate, piano wire piece, and CIM mount). How different is the new model? Could anyone post or PM me dimensions or changes that need to be made in order to work with the new model so our team could get started this weekend?
Richard
The primary difference in dimension for us is the hole pattern. In DWG NO. 1 (Chiaphua Plate) from the NBD paper, we replaced the 0.6875" dimension with 0.745" and the 1.055" dimension with 1.110". Since this hole pattern is larger than the DC980 model, the plate needs to have a larger OD. We used 3". The servo plate will need a bit of adjusting as well to accomodate the larger hole pattern.
We do not use the method of boring out the sun gear as described in the NBD Paper, so I cannot speak to any mods needed on the transmisison case. Last year we successfully used the StevenB method of using a "sun gear adaprter" described in this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=50091
It worked beautifully for us last year.
Hope this helps you get started. Let me know if you need more info.
Mike Zanghi
Team 624 CRyptonite Robotics
pic: Canadian Carnage Koko Ed Extra Discussion 7 26-09-2006 17:04
pic: 862: Camera Carnage 2 Joe J. Extra Discussion 2 11-03-2006 22:40
pic: FRC 488 -- Poof Ball Carnage Madison Extra Discussion 2 06-03-2006 19:01
rObO cArNaGe pyro20911d General Forum 6 16-02-2006 00:17
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
