Go to Post Edison was once asked "how do you come up so many good ideas?" to which he responded "for every good idea, I have 99 bad ideas first." - dlavery [more]
Unread 19-01-2008, 16:27
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
Re: pic: A closup view of our prototype worm-crab drive system.
Glad to see this get brought back up.
Each gearbox has a vertical CIM motor with a worm on the end. It turns a spur gear that is connected to the output axle that the wheel is mounted on. The whole gearbox sits in a UHMW block that we added grooves to for cables to run through.
The UHMW blocks sit on a 1/4" thick aluminum plate attached to the frame. Each of these blocks are tied together using cable that is wound around another UHMW pully that is connected to the window motor.
When the window motor turns, so do the gearboxes. Here are some links to more pictures of this drive.
http://www.chiefdelphi.com/media/photos/28616
http://www.chiefdelphi.com/media/photos/28615
http://www.chiefdelphi.com/media/photos/28499
http://www.chiefdelphi.com/media/photos/28498
http://www.chiefdelphi.com/media/photos/28612
This is last years drive keep in mind. Not this years.
pic: Cooney 269's Worm Crab Gearbox Interior AndyB Extra Discussion 11 28-04-2007 18:48
FRC 269 Worm Crab 2007 Video Ricky Q. Robot Showcase 3 21-02-2007 20:59
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
