Re: pic: 1726 Overdrive Chassis CAD
We will have bumpers all the way around the robot, and the cantilevered axles are definitely strong enough, and are well supported. The Inventor rendering does not have all the parts on it...so you can see the interesting stuff....but there is more to the robot!
We used a fiberglass I beam turned on it's side for the main frame rails on last years robot, with a thru bolted dead axle. It was quite a bit harder to build, this year we are going for maximum ease of construction, along with a solid, reliable, effective design. We'll see how it does. Hopefully we'll get some ball handing mechanism pictures up in the next week or so. The catapult experiments went well today, it behaves very safely when not loaded with a ball, and shot a 30" exercise ball (using 1/4 the final pneumatic cylinder capacity) almost high enough to clear the overpass. Should be fun! |
Today we built the transmissions and put an axle on a scrap piece of c-channel to test how strong it is. The axle setup is very solid, and i can't see it breaking under any load the robot will see.
My team has used a cantilevered dead axle system for the past three years with only one major issue that i can remember: bumper mounts. Last year's solution, which proved to be waaay too much trouble was to tap holes into the axles to receive the bolts from our bumpers. May I suggest that you consider integrating mount points into the frame. (I'm pretty sure you already have an adequate solution, though.)
| pic: HALO 3 overdrive(2) | justsomekid | Extra Discussion | 47 | 14-05-2008 17:30 |
| pic: HALO 3 overdrive(1) | justsomekid | Extra Discussion | 14 | 19-01-2008 10:10 |
| pic: 1726 Promobot | GUI | Extra Discussion | 18 | 01-11-2007 18:04 |
| pic: 1726 2007 OI | TheOtherGuy | Extra Discussion | 2 | 11-02-2007 23:17 |
| pic: Team 1726 MegaMaid Motors/Chassis/electronic board | yodameister | Robot Showcase | 3 | 11-02-2006 01:21 |
