Go to Post my theory on the matter was always something along the lines of "Oh, we're all girls? What an odd thing for you to notice." - karinka13 [more]
Unread 19-01-2008, 23:35
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: pic: DeWalt carnage
Originally Posted by MikeZ View Post
Richard
The primary difference in dimension for us is the hole pattern. In DWG NO. 1 (Chiaphua Plate) from the NBD paper, we replaced the 0.6875" dimension with 0.745" and the 1.055" dimension with 1.110". Since this hole pattern is larger than the DC980 model, the plate needs to have a larger OD. We used 3". The servo plate will need a bit of adjusting as well to accomodate the larger hole pattern.
We do not use the method of boring out the sun gear as described in the NBD Paper, so I cannot speak to any mods needed on the transmisison case. Last year we successfully used the StevenB method of using a "sun gear adaprter" described in this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=50091
It worked beautifully for us last year.
Hope this helps you get started. Let me know if you need more info.
Mike Zanghi
Team 624 CRyptonite Robotics
Thanks for the help Mike.....I had one other question for you or anyone else....what are the most common ways of mounting the gearboxes? The only way I've seen is using the aluminum shaft collars from mcmaster, and welding them to the frame. We are using the kit frame this year and don't have welding capabilities. Has anyone ever used Dewalts for a drive system on the KOP frame?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
pic: Canadian Carnage Koko Ed Extra Discussion 7 26-09-2006 17:04
pic: 862: Camera Carnage 2 Joe J. Extra Discussion 2 11-03-2006 22:40
pic: FRC 488 -- Poof Ball Carnage Madison Extra Discussion 2 06-03-2006 19:01
rObO cArNaGe pyro20911d General Forum 6 16-02-2006 00:17
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
