Go to Post This thread is a reminder to myself that I have 29 more days to sleep. :) - Seth Mallory [more]
Unread 20-01-2008, 14:33
MikeZ MikeZ is offline
FRC #0624 (CRyptonite)
MikeZ has a spectacular aura aboutMikeZ has a spectacular aura about
Re: pic: DeWalt carnage
Originally Posted by richardmcc2 View Post
Thanks for the help Mike.....I had one other question for you or anyone else....what are the most common ways of mounting the gearboxes? The only way I've seen is using the aluminum shaft collars from mcmaster, and welding them to the frame. We are using the kit frame this year and don't have welding capabilities. Has anyone ever used Dewalts for a drive system on the KOP frame?
Richard
Here is a link showing how we mounted the Dewalts on our 2007 robot kit frame without welding. We tapped and threaded the lower half of the collar clamp, and designed the CIM plate to serve as a mount as well. We machined and bolted a "drivetrain pan" to the kit frame. The lower half of the collar clamp and CIM plate/mount were then secured to the drivetrain pan with bolts from underneath. From the pic you can also see how we used some sliders to adjust chain tension.
http://www.chiefdelphi.com/media/photos/29730
Mike Zanghi
FIRST Team 624
CRyptonite Robotics
pic: Canadian Carnage Koko Ed Extra Discussion 7 26-09-2006 17:04
pic: 862: Camera Carnage 2 Joe J. Extra Discussion 2 11-03-2006 22:40
pic: FRC 488 -- Poof Ball Carnage Madison Extra Discussion 2 06-03-2006 19:01
rObO cArNaGe pyro20911d General Forum 6 16-02-2006 00:17
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
