Go to Post I think a 100% student-run team is as good as a school taught by your peers. - [more]
Unread 20-01-2008, 21:46
dtengineering's Avatar
dtengineering dtengineering is online now
AKA: Jason Brett
Re: Arm mechanism
Originally Posted by team 2191 View Post
How does having a telescoping arm sound with rollers inside??
It sounds like "whirr" if you do it right, and "clack clack grunge snap @$@%^!!" if you don't.
You may also want to look at the IGUS bag of materials and contact them about their YES program. IGUS is very generous about donating some excellent materials to teams, so if you see something you like in the KOP and would like more, you should contact IGUS with your ideas.
There is also a powerpoint on lifts and how to build them on the FIRST website somewhere... anyone got the link to that one?
Jason
Unread 20-01-2008, 21:57
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Arm mechanism
In 2005 we had a telescoping arm which had HDPE (High-density polyethelene) blocks inside on which the aluminum rectangular form slid, instead of rollers. The friction is quite low, the simplicity, stability and durability quite high. Let me know if you need more details.
Don
Unread 20-01-2008, 22:10
in between teams
AKA: Luke Van Oort
Re: Arm mechanism
Don
We did the same thing (same year too) and I would warn against it. Although the basic design is solid, we discovered that HDPE blocks cut in dry, cold January don't work too well in humid, warm Atlanta. Instead of HDPE, I would used UHMW (Ultra-High Molecular Weight) Polyethylene, which doesn't have those problems (or, at least, not anywhere near as bad).
Team 1219: 2009 - Mentor
Unread 23-01-2008, 22:40
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
Re: Arm mechanism
Can someone please email me with details on how to make a telescoping arm because i dont really understand how to make one or even how it works.
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 24-01-2008, 07:15
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Arm mechanism
Is Building Competative Manipulators by Greg Needel the one you are thinking of?
Mark
Brick walls are for other people. - Randy Pausch
Human Arm Arm Controller SgtMillhouse648 Control System 5 09-01-2008 00:03
424's 2007 robot arm is very similar to 340's 2004 robot arm. Ross340 Robot Showcase 7 19-11-2007 21:11
Shooting Mechanism detctboylos007 Rules/Strategy 9 02-02-2006 15:24
Arm design - rotation mechanism? n0cturnalxb Technical Discussion 6 16-01-2005 18:28
Caster Mechanism mzitz2k Technical Discussion 11 01-01-2004 17:01
