Go to Post "Scientists investigate that which already is; Engineers create that which has never been." - Albert Einstein - JamesCH95 [more]
Unread 21-01-2008, 18:24
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Re: pic: Team 56 Trackball Launcher Test
It looks like its a pneumatic piston pushing the ball, I have to wonder how the plan on shooting more than once... (Pushing a ball with a piston like that is hard, and takes a lot of air)
I agree that there is no way that overpass is at 6'6". Also, (we ran into this) I wonder if the ball was in a "realistic" position, that is, if it was on the robot would it intersect whatever is getting the ball getting up that high.
Really, simpler is better; really, I swear
WHY DON'T YOU BELIEVE ME???
Unread 21-01-2008, 20:43
jfischer's Avatar
jfischer jfischer is offline
AKA: Jerry Fischer
None #0056 (ROBBE Xtreme)
jfischer will become famous soon enough
Yes the overpass is too low in this test, but we set up our launcher to match the height of the overpass. Tonight we ran the launcher on the real field and got similar results. Basically, it's powered by a 1.5" cylinder running at 60 psi.
Unread 22-01-2008, 08:22
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
yeah seems about right, when we ran tests it seemed to me the best cylinder to use was a 1.5" bore! How long is the stroke??
Unread 22-01-2008, 08:32
jfischer's Avatar
AKA: Jerry Fischer
We used the 11" stroke. The key to getting maximum travel seems to be the angle of the cylinder and the shape of the pusher. I'm sure we will see some very interesting designs.
Unread 10-02-2008, 11:54
sundancekid92 sundancekid92 is offline
FRC #0056 (ROBBE XTREME)
sundancekid92 has a spectacular aura aboutsundancekid92 has a spectacular aura about
yeah robbe the real thing is going to be awsome
pic: Trackball vs. MiniFRC Trackball Jessica Boucher Extra Discussion 3 08-01-2008 03:08
pic: Team 237 Easter inspired Trackball grabber Elgin Clock Extra Discussion 3 07-01-2008 23:34
pic: Ramp Drop Test Team 1583 WRGibbens Extra Discussion 12 09-02-2007 02:42
pic: Team 1712 First Test IraJason Robot Showcase 3 15-02-2006 14:18
pic: Team 1501's launcher Wayne Doenges Extra Discussion 2 21-01-2006 18:52
