pic: All light originates from the welders arc.
Re: pic: All light originates from the welders arc.
Is that MIG alum? If it is, your lucky im stuck with a really old TIG welder hehe, but i still love it.
ya it's a MIG aluminum welder
it's pretty tough using it, we only got 2 good beads out of it. everything else pretty much oxidizes on the spot and pops. |
I love MIG welding, TIG welding is slow. But it makes great welds if you can do it well.
I've never heard about aluminum MIG welders working that well. Just go TIG.
I took a welding class at school last year and we where tought how to MIG alum weld. It was a good Miller Welder and I loved it. It was quick and easy to learn once i got MIG steel down.
Its the over all penetration for aluminum MIG welding kinda poor?
(Then again Im only familiar with Hobart Handlers) |
the penetration is up to 1/8th an inch with the 110v system that we have. It gets the job done.
i'm an amateur photographer, and i think this is a beautiful photo.
#10
Unfortunately our MIG is only set up for steel. It makes me sad.
Oh how I wish we could weld our chassis, instead of those ugly bolts. |
#11
when i was welding 3/16 plate alum i had good penetration.
#12
MIG alum's are nice... i have done a bit of work with one... not on a bot tho... we don't a welder at all!!! i wish we did... maybe next year...
#13
Is there no spool gun is it just out of the picture. I had always thought with aluminum wire, you had to use a remote spool because the weak wire can not push through the line.
#14
We've had problems with the wire breaking off inside of the line, though most of the time it seems to be alright. |
#15
i'am the welder
I used .030 aluminum wire in the stock lincon electric 120v welder. I was able to get a couple beads but the wire does not want to feed and it splashes. lincon sells a kit to make it spool perfectly, it includes aluminum wire rollers and aluminum wire line sheath to go inside the gun cable to prevent the soft Al wire from binding. you will also need 100% argon gas to weld Al |
| How do YOU find the distance from the light? | Spencer E. | Programming | 13 | 24-03-2007 20:44 |
| camera trouble,cant tell the green-light from regular white light | Nimmy | Programming | 26 | 14-01-2007 14:53 |
| Our Camera runs away from the light?!?!? | team1500 | Programming | 16 | 06-02-2006 19:58 |
| Questions on MIG Welders | Jay H 237 | Technical Discussion | 21 | 12-05-2005 21:47 |
| About the light that need to be seen from four side | archiver | 2000 | 3 | 23-06-2002 23:01 |
