Go to Post Who cares about the score? The score is just numbers on a board, the exciting part is watching the robots interact and seeing robots( and more importantly, people) do the impossible. - Herodotus [more]
Unread 21-01-2008, 22:09
King Duke's Avatar
King Duke King Duke is offline
FRC #0991 (Dukes)
King Duke is a jewel in the roughKing Duke is a jewel in the roughKing Duke is a jewel in the rough
Send a message via AIM to King Duke
pic: All light originates from the welders arc.
Unread 21-01-2008, 22:10
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: pic: All light originates from the welders arc.
Is that MIG alum? If it is, your lucky im stuck with a really old TIG welder hehe, but i still love it.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 21-01-2008, 22:21
King Duke's Avatar
FRC #0991 (Dukes)
ya it's a MIG aluminum welder
it's pretty tough using it, we only got 2 good beads out of it. everything else pretty much oxidizes on the spot and pops.
Mr. Ames
#991 The DUKES!!!!! from Phoenix, Arizona
Cornell MineSweeper- Business is Booming.
Unread 21-01-2008, 23:03
That guy
AKA: Dennis
I love MIG welding, TIG welding is slow. But it makes great welds if you can do it well.
Unread 21-01-2008, 23:39
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
I've never heard about aluminum MIG welders working that well. Just go TIG.
Unread 21-01-2008, 23:43
That guy
AKA: Dennis
I took a welding class at school last year and we where tought how to MIG alum weld. It was a good Miller Welder and I loved it. It was quick and easy to learn once i got MIG steel down.
Unread 21-01-2008, 23:49
M4 Sherman's Avatar
Its the over all penetration for aluminum MIG welding kinda poor?
(Then again Im only familiar with Hobart Handlers)
Unread 22-01-2008, 00:05
King Duke's Avatar
FRC #0991 (Dukes)
the penetration is up to 1/8th an inch with the 110v system that we have. It gets the job done.
Mr. Ames
Unread 22-01-2008, 01:16
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
i'm an amateur photographer, and i think this is a beautiful photo.
Unread 22-01-2008, 01:59
mbeardsworth mbeardsworth is offline
Lord of the Subversion Repository
AKA: Michael Beardsworth
FRC #2521 (South Eugene High School Robotics)
mbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of light
Unfortunately our MIG is only set up for steel. It makes me sad.
Oh how I wish we could weld our chassis, instead of those ugly bolts.
Unread 22-01-2008, 10:01
That guy
AKA: Dennis
when i was welding 3/16 plate alum i had good penetration.
Unread 22-01-2008, 15:48
Martino's Avatar
Martino Martino is offline
FRC #1825
Martino is on a distinguished road
Send a message via AIM to Martino Send a message via MSN to Martino
MIG alum's are nice... i have done a bit of work with one... not on a bot tho... we don't a welder at all!!! i wish we did... maybe next year...
Unread 22-01-2008, 16:12
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
Is there no spool gun is it just out of the picture. I had always thought with aluminum wire, you had to use a remote spool because the weak wire can not push through the line.
Unread 22-01-2008, 23:45
King Duke's Avatar
FRC #0991 (Dukes)
Thank you, I'm amateur photographer as well. Always looking for hints and tips to make it better though.
hmmmm interesting point.
We've had problems with the wire breaking off inside of the line, though most of the time it seems to be alright.
Mr. Ames
Unread 30-01-2008, 23:12
Nick02's Avatar
Nick02 Nick02 is offline
AKA: nick
FRC #0991 (Dukes)
Nick02 is an unknown quantity at this point
i'am the welder
I used .030 aluminum wire in the stock lincon electric 120v welder.
I was able to get a couple beads but the wire does not want to feed and it splashes.
lincon sells a kit to make it spool perfectly, it includes aluminum wire rollers and aluminum wire line sheath to go inside the gun cable to prevent the soft Al wire from binding.
you will also need 100% argon gas to weld Al
Nick mechanical/electrical
El Presidente of brophy robotics
How do YOU find the distance from the light? Spencer E. Programming 13 24-03-2007 20:44
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
Our Camera runs away from the light?!?!? team1500 Programming 16 06-02-2006 19:58
Questions on MIG Welders Jay H 237 Technical Discussion 21 12-05-2005 21:47
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
