Go to Post and the only thing i see as a disadvantage to those long hours of hard work is a little less time to spend with my girlfriend - h1n1is4pigs [more]
Unread 22-01-2008, 20:22
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: Team 665 REAL Chassis, Kinda-Teaser
Awesome! I was really hoping someone would make a drivetrain like that. Does it have a differential, too?
Unread 22-01-2008, 21:07
johnnysanchez johnnysanchez is offline
FRC #2582
johnnysanchez is an unknown quantity at this point
Red face Re: pic: Team 665 REAL Chassis, Kinda-Teaser
cool so is weight going to be a issue
Unread 22-01-2008, 21:09
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Front wheel steering should work out great. Nice job!
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 22-01-2008, 22:11
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
that looks a wee bit familiar:
http://www.chiefdelphi.com/media/photos/14037
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 22-01-2008, 22:18
Corey Oostveen's Avatar
Corey Oostveen Corey Oostveen is offline
FRC #2771 (Code Red Robotics)
Corey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant future
looks great. I look forward to seeing how the Ackermann Drives work in competition.
Unread 22-01-2008, 23:12
Super Serb's Avatar
Super Serb Super Serb is offline
Petar Cvetojevic
AKA: Crazy Serbian Kid
FRC #1228 (A-Merck-In-Indians)
Super Serb is on a distinguished road
Send a message via AIM to Super Serb
i think theres more there than the Ackerman i think i see a differential between the back wheels....if there isnt 1 then good luck turning without binding....
Unread 23-01-2008, 20:47
Laxphan1525's Avatar
Laxphan1525 Laxphan1525 is offline
AKA: Harrison
FRC #1525 (Warbots)
Laxphan1525 is an unknown quantity at this point
where did you guys get your differential from?... i've been looking for one of those for one of my go-karts. Also it doesn't look like you have a huge turning radius with those inside rail of the kop in the way?
Unread 23-01-2008, 21:30
AKA: Harrison
FRC #1525 (Warbots)
there wont be binding created without a differential your treads on your tires will just have to be slick so you can power slide the back end through the turns kinda of like drifting in Need for Speed Underground or Tokyo Drift. Also if you were controlling the rear wheels independently you could program the robot to rotate the wheels at different rpm when executing a turn which would eliminate some of the force exerted on the robot during turns.
Unread 23-01-2008, 21:52
Schooj's Avatar
Schooj Schooj is offline
FRC #0665 (MAYHEM)
Schooj is an unknown quantity at this point
The differential is from Northern Tools, we prototyped this design 2 years ago so we already have a good idea of its capabilities. The weight is about the same as our standard 6wd.
"I reject your reality and substitute my own." -Mythbusters
Unread 25-01-2008, 08:09
Super Serb's Avatar
Petar Cvetojevic
if you powerslide through turns then you would risk losing control of your bot which isn't something to risk plus you will lose time if you have a fast robot because you would have to wait until you regain traction its not much time but every second will help...as for a differential programmed has anyone tried it?
Unread 25-01-2008, 08:14
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
So you used a go-kart diff on the back end? Sweet!
Are you using a homebrew servoset for the steering?
If you have an automotive sponsor (GM, Ford,...) you should see if they can give you a graphic for "Electic Power Steering" or make one yourself.
Are you going for autonomous? I guess your putting an encoder at the tire since you won't be able to figure out (easily) from the shifter how far you've gone?
-q
Electrical Engineer Illini
Team 665 TheFuhr Robot Showcase 13 23-01-2008 13:04
pic: Team 306 REAL Teaser #2 Cody Carey Robot Showcase 3 06-02-2006 22:58
pic: Team 1676 Chassis Teaser Spiffizzle Robot Showcase 10 28-01-2006 23:53
pic: ThunderChicken Chassis Teaser Swan217 Robot Showcase 1 01-03-2005 19:11
pic: Teaser: 617 Chassis jrocket567 Robot Showcase 26 03-02-2005 09:05
