Re: pic: 1726 Overdrive Chassis CAD
Today we built the transmissions and put an axle on a scrap piece of c-channel to test how strong it is. The axle setup is very solid, and i can't see it breaking under any load the robot will see.
My team has used a cantilevered dead axle system for the past three years with only one major issue that i can remember: bumper mounts. Last year's solution, which proved to be waaay too much trouble was to tap holes into the axles to receive the bolts from our bumpers. May I suggest that you consider integrating mount points into the frame. (I'm pretty sure you already have an adequate solution, though.)
| pic: HALO 3 overdrive(2) | justsomekid | Extra Discussion | 47 | 14-05-2008 17:30 |
| pic: HALO 3 overdrive(1) | justsomekid | Extra Discussion | 14 | 19-01-2008 10:10 |
| pic: 1726 Promobot | GUI | Extra Discussion | 18 | 01-11-2007 18:04 |
| pic: 1726 2007 OI | TheOtherGuy | Extra Discussion | 2 | 11-02-2007 23:17 |
| pic: Team 1726 MegaMaid Motors/Chassis/electronic board | yodameister | Robot Showcase | 3 | 11-02-2006 01:21 |
