Go to Post The flux capacitor should have been allowed under the flowchart as long as it met the single component maximum cost. I did check with Digikey and they no longer carry the line. - Al Skierkiewicz [more]
Unread 23-01-2008, 09:57
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: pic: 1225's 2008 Electrical Board
Looks pretty good. Last year, IFI had recommended that the radio modem be mounted vertically (there's an antenna inside the case, in addition to the external one). For safety, I'd put a little electrical tape on the positive connection to the ATC panel, since it's very close to the negative.
Do you have enough room on the right side to get the serial cables in and out of the robot controller once it's mounted on the robot? They take up quite a bit of room.
pic: 469 Electrical Board Don Wright Extra Discussion 11 12-03-2007 21:17
pic: Time for a clean electrical board? Arefin Bari Extra Discussion 11 31-01-2007 22:39
pic: 494 Electrical Board underside want2modmygt Robot Showcase 2 14-02-2006 17:31
pic: 494 Electrical Board underside close up want2modmygt Robot Showcase 2 13-02-2006 08:30
pic: 494 Electrical Board. want2modmygt Robot Showcase 2 12-02-2006 14:28
