Go to Post It made me want to do a swerve drive, but then I smacked myself. - Nemo [more]
View Poll Results: What's your favorite meathod of connection?
Zip-tyes 15 31.25%
Rivet 5 10.42%
Weld 12 25.00%
Bolt/lock-tight 13 27.08%
Glue/Epoxy 1 2.08%
Other 2 4.17%
Voters: 48. You may not vote on this poll
Unread 23-01-2008, 21:02
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Your favorite meathod of connection
What connection method is the most vital to the success of your robot?
pick one
Edit: fixed
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 23-01-2008, 21:04
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Your favorite meathod of connection
This question probably needs a little (or a lot) of clarification before you'll get the answers you want.
EDIT: Okay now that this is fixed I can provide a better answer. In my opinion none of these are "better" or "more vital to the success of a robot" than any other, there are correct applications for each of these types of fastening and using each fastner appropriately is the real key. Zip-tying the entire robot is impractical as is welding on your flag holder, for each spot you need to connect two items assess the situation and choose the best method that fits within team capabilities (welding may be out for example)
Unread 23-01-2008, 21:08
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
"What connection is the most vital to the success of your robot?"
There are two: the one between the drivers brain and hands, and the one between the coaches brain and mouth. None of the other ones matter if those two don't work.
-dave
Unread 23-01-2008, 21:10
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
-dave
well with autonomous wouldn't drivers and coaches not matter??
Unread 23-01-2008, 21:11
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
What about the batteries terminals connections? You can't move without power.
EricH EricH is online now
In that case, it's between the programmer's brain and hands.
Unread 23-01-2008, 21:12
Woody1458's Avatar
AKA: Woody Jansen
I would consider that more of a kind of connection not a meathod
GO DANVILLANS!!
Unread 23-01-2008, 21:17
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
It all really depends...
I'm not going to vote because of this.
How would I attach metal to metal: Weld
How would I attach wood to metal: Bolt & Loctite
How would I attach wires to something: Ziptie
I would obviously not say:
How would I attach wires to something: very flammable epoxy and weld it
How would I attach the wheels to the frame: zipties
How would I attach the bumpers: small pop rivets
See, this question still very vague. Please fix it.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 23-01-2008, 21:20
Andy L's Avatar
FRC #1458
which one of these is most important as in ziptieing wires is not really as important as welding your frame so welding would be above that and so on and so on
Unread 23-01-2008, 21:21
Woody1458's Avatar
AKA: Woody Jansen
Its hard to repsond to your post without being unGP. Sooooooooo thank you for your input.
GO DANVILLANS!!
Unread 23-01-2008, 21:25
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Not true, wires that are not secured properly can be as devastating if not more so then a frame that is bolted, riveted or even glued as opposed to welded. If wires come loose your robot will be lucky to run at all, if your frame starts to fall apart you may still move, although likely not very well.
Unread 23-01-2008, 21:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
*cough* Hybrid *cough*
Unread 23-01-2008, 21:35
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Welds by far.
That rug really tied the room together...
Unread 23-01-2008, 21:46
in between teams
AKA: Luke Van Oort
I think you'd be amazed at the number of robots and variety of things on them held together by zip-ties. Without zip-ties, our robot last year would have had a completely non-functional arm... zip ties tensioned all of our arm chains, which sorely needed it, and served their usual purpose - keeping wires out of where they shouldn't be (like crushed between a sprocket and its chain, which happened once). Our electronics cover was also zip tied on. This year, our electronics will be zip-tied on. I have even seen zip ties used as linear bearings (which was a pretty creative use, in my opinion) on an arm. Sure, I wouldn't design to hold my chassis together with them, but I much prefer working with zip ties to drilling out rivets, worrying about messing up the aluminum's heat-treatment, finding nuts dropped on the floor/magnetically stuck to the side of a motor casing, realizing that you epoxied the part in the wrong place (<--happened this week), and whatever annoyances are associated with other fastening methods.
Team 1219: 2009 - Mentor
Unread 23-01-2008, 22:12
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Our aim high robot was held together with at least 5 pounds worth of zip ties, so I vote for them.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Dress as your favorite CD-er! Jessica Boucher Chit-Chat 5 01-11-2004 09:12
How fast is your internet connection? Wetzel Chit-Chat 56 10-10-2003 15:40
Who's your favorite X-men Aaron Lussier Chit-Chat 8 28-06-2002 09:39
Your Internet Connection Tom Fairchild Chit-Chat 28 05-01-2002 21:57
