Re: pic: Team 665 REAL Chassis, Kinda-Teaser
there wont be binding created without a differential your treads on your tires will just have to be slick so you can power slide the back end through the turns kinda of like drifting in Need for Speed Underground or Tokyo Drift. Also if you were controlling the rear wheels independently you could program the robot to rotate the wheels at different rpm when executing a turn which would eliminate some of the force exerted on the robot during turns.
The differential is from Northern Tools, we prototyped this design 2 years ago so we already have a good idea of its capabilities. The weight is about the same as our standard 6wd.
So you used a go-kart diff on the back end? Sweet!
Are you using a homebrew servoset for the steering? If you have an automotive sponsor (GM, Ford,...) you should see if they can give you a graphic for "Electic Power Steering" or make one yourself. Are you going for autonomous? I guess your putting an encoder at the tire since you won't be able to figure out (easily) from the shifter how far you've gone? -q |
| Team 665 | TheFuhr | Robot Showcase | 13 | 23-01-2008 13:04 |
| pic: Team 306 REAL Teaser #2 | Cody Carey | Robot Showcase | 3 | 06-02-2006 22:58 |
| pic: Team 1676 Chassis Teaser | Spiffizzle | Robot Showcase | 10 | 28-01-2006 23:53 |
| pic: ThunderChicken Chassis Teaser | Swan217 | Robot Showcase | 1 | 01-03-2005 19:11 |
| pic: Teaser: 617 Chassis | jrocket567 | Robot Showcase | 26 | 03-02-2005 09:05 |
