Go to Post FIRST describes this program as students working "side by side" with professional mentors. We describe our team as working "shoulder to shoulder." Maximum learning happens with maximum interaction between students and mentors, whenever and wherever that may be. - jspatz1 [more]
Unread 23-01-2008, 23:52
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
Re: pic: Bike quick release part 2
Originally Posted by Peter Matteson View Post
Did you cut the shaft and re-thread it?
If so do you still get an appropriate preload when you toggle the cam? I would be worried about overloading an unthreaded length that long and causing plastic deformation.
FYI I am pro using bicycle parts on robots.
They make short ones and few spacers help. There isa very good grip as usual,we have not lost a battery in three years.
Faridodin "Fredi" Lajvardi KD7WKD
Unread 24-01-2008, 07:39
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Thanks just curious because I hadn't seen them that short before, the preload thing has to do with a failure investigation I conducted last year though. One detail missed caused a big mess.
Thank-you 294 & 67
www.bobcatrobotics.org
Quick Vacuum Release Calvin_1631 Pneumatics 8 05-02-2007 20:49
pic: Bike Cim + 56 mm gearbox NK2007 Extra Discussion 7 15-01-2007 01:10
pic: BIKE NYC! Rich Wong Extra Discussion 5 12-05-2006 13:17
Quick release wire harness mechanicalbrain Electrical 2 08-01-2006 15:36
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
