Go to Post Brandon Martus, making CD readers' lives easier since May 2001/Fall 98 - Beth Sweet [more]
Unread 25-01-2008, 17:10
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
pic: Virginia's rear ground clearance
Unread 25-01-2008, 17:11
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: Virginia's rear ground clearance
hey your clearance is just a bit higher than our lol nice!! looks good!
Unread 25-01-2008, 17:16
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Have you tried taking it over a 1/2 inch bump? The frame will make it over fine, but those motors look like they may have some trouble.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 25-01-2008, 17:19
FRC #1360
Joey
the wheels will hit before the motors will as far as I can tell
Unread 25-01-2008, 17:24
AKA: Joey
That is if you are going over perpindicularly to the bump it will be fine. If it goes where one wheel goes over before the other it will have wheels on either end of the bump, with the motors sitting on top of the bump. I dont know how far the motors are from the ground though. I just dont want you to get to the competition and realize you cant get over the bump.
Joey
Unread 25-01-2008, 17:28
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
Not if you are straddling the 1/2 the bump between the drive wheels. Our chassis height is adjustable from about .25" up to 1.00". The only issue is it is entirely below the bumpers. You may want to make provisions for a little more clearance if needed. A little larger diameter wheel will do it.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
Unread 25-01-2008, 17:30
FRC #1360
Joey
true enough, forgot about the not hitting it straight on thing lol
my bad
Unread 25-01-2008, 23:31
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
If this team lives up to what i have seen in the past it has been checked and will not get stuck.
pic: Virginia's Pnuematics falconmaster Extra Discussion 9 25-01-2008 02:35
Think about Robot Ground Clearance ggoldman General Forum 12 10-01-2007 08:22
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
pic: 857 rear view programming CD47-Bot Robot Showcase 1 25-02-2003 22:24
