Originally Posted by lukevanoort
Instead of trusting a team member's information (which can be wrong) or info from post on CD (which can also be wrong, but someone usually corrects incorrect answers), you should read the manual yourself. Reading the relevant sections only takes about an hour to a couple of hours; the amount of time it takes depends on reading speed and what sections are relevant--a build team person probably doesn't need to read the criteria for the website award, for example (although it is probably a good idea to do so anyway). Even if it takes 4hrs, it will be the most useful 4hrs you spend all build season.
Thanks for the help. I read the manual, and so did the team member who thought it needs to be mounted verticly. The problem is the manual contains so much info, that it is hard to remember all of it. We were going to look through the manual for it, but I saw the picture of it mounted sideways, so I thought I would ask.
Joey
