Go to Post at what point does gracious professionalism turn into cut throat competition? - aepstein [more]
  #106   Spotlight this post!
Unread 02-01-2008, 08:02
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: White Paper Discuss: Nothing But Dewalts
Originally Posted by richardmcc2 View Post
Does anyone know of a place to find the DC980KA anymore?
Try checking with your local Dewalt service center. They have always had them in stock for us.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
  #107   Spotlight this post!
Unread 03-01-2008, 00:59
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
We found its more expensive to use the older drill model. We are changing our tranny because of it. Buying the individual parts of the drill will cost more than buying a whole new model drill.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
  #108   Spotlight this post!
Unread 25-01-2008, 19:20
adaballer5's Avatar
adaballer5 adaballer5 is offline
FRC #1388
adaballer5 is an unknown quantity at this point
Our Dewalt transmissions are making a weird binding sound when we shift into third gear and i was wondering if this is normal or not. We've taken apart the trans and the gears are fine. We are just worried about the sound. Is this a typical sound?
Jim: Don't listen to Mudd, everything he says is a lie.
Mudd: I'm lying.
Team 1388 FTW
  #109   Spotlight this post!
Unread 25-01-2008, 20:55
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Smile Re: White Paper Discuss: Nothing But Dewalts
We've use them for several years as our man drive, and have found them to be very smooth. Are you driving them with CIMs? Be certain the sun gear is not too deep into the planetary gears in the 1st stage. In addition, we have not had a need to use super low, as there is not much difference in ratio between 2nd and 3rd. Possibly, if you are using a servo to shift, it may not have enough throw, and you're not fully into 3rd gear. Did you remove the clutch pins from the output shaft? Are you still using the torque ring adjustment?
  #110   Spotlight this post!
Unread 01-12-2009, 22:09
kcedgerton kcedgerton is offline
FRC #0418
kcedgerton is an unknown quantity at this point
The old Dewalt transmissions have become very expensive, has anyone had success using a newer model dewalt?
  #111   Spotlight this post!
Unread 01-12-2009, 22:27
ajlapp ajlapp is offline
AKA: Anthony Lapp
Team RUSH has switch to the 36v Dewalt housing with great success. The procedures for modifying them are similar.
We don't have a white paper, sorry...but, you can sort of see them in this picture. They are substantially more rugged, featuring more drive pins inside the planetary assembly.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
  #112   Spotlight this post!
Unread 20-01-2010, 21:13
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
We are trying to use the Fischer price assembly for the dewalt and we are having some problems. The paper is very vague in how it describes the modified pinion gear and we have a whole lot of questions
  • What gear is this?
  • Is it from the dewalt tranny?
  • is it from the Fischer Price motor?
  • how do we modify it?
  • How do we attach it to the Fischer price? When we tried to take off the gear that came with a Fischer Price we practically destroyed it Fischer price.
  • Can someone help us?
thank you in advance
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
  #113   Spotlight this post!
Unread 22-01-2010, 00:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The modified pinion gear is a modified dewalt pinion gear. The mention is in the very first paragraph on page 17. It notes that the Sun1 (pinion) gear id the same gear as the Planet2 gear. This would be the planet gears of the second stage of the tranny. There's 4 of them and they're longer than the Planet1 gears.
Modified means bored out to a press fit on the FP shaft. He recommends a .125 (+0.0000, -0.0005) hole. This is a very tight press fit, which makes it a little tricky to not bend your FP shaft. I'd recommend measuring your FP shaft with some micrometers and going with a hole that's 0.0005 under your measured dimension.
