Go to Post Relax. Have fun. Enjoy the improvements. Build what you want to. - Rich Kressly [more]
Unread 26-01-2008, 09:56
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
pic: shaft
Unread 26-01-2008, 09:59
Doug G's Avatar
Doug G Doug G is online now
Coach / Teacher
FRC #0701 (Robovikes)
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Re: pic: shaft
Couple of questions..
1. What diameter is the shaft?
2. Why aren't you using steel?
This year we are trying live aluminum axles for the first time. We chose 1/2" hex, hopefully they hold up.
Work Hard, Have Fun, Make a Difference!
Unread 26-01-2008, 10:02
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: pic: shaft
Steel is real man...
Unless you are completely strapped for weight, drivetrain shafts should be robust enough to get through a competition maitnenence free (just opinion here).
Without a working drivetrain you may as well just put a battery with a team number and a flag holder on the field!
RAZ
Unread 26-01-2008, 11:28
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: pic: shaft
Looks like a nice shaft..from the left of the damage. Is that 6061, 7075, or 7068?
Do the Outbacks come with that Aluminum shaft or did you just make it yourself? If they came with, then they seem to be the Banebots of last year.
Unread 26-01-2008, 12:30
rachal's Avatar
multipurpose tool
AKA: Rachel
Re: pic: shaft
The shaft came from the Outbacks we bought last year and are using as a practice bot, didn't know they were aluminum until a few days ago. I would never use aluminum axles
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 26-01-2008, 14:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: shaft
There's no way those are 7075 or 7068, or anything stronger than 6061. We've been using 7075 for years, and we've used and abused all our robots. We've never even seen serious wear to a keyway in 7075, letalone something as mangled as this.
I wouldn't look at this as a testament to why steel is better. I'd look at it as a prime example of what happens when you choose the wrong alloy material for a high stress application. Many teams have been using aluminum shafts with great success. There really is no reason to use steel, if you have the proper machining resources to make your own shafts out of Al.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-01-2008, 15:16
Re: pic: shaft
6061 isn't a great alloy for transmitting torque through keyways or such things with high stress concentration factors. 696 used 1/2" axles with 1/8" keyways out of 2024 Aluminum (McMaster pre-keyed stock) last year with 5" wheels geared for 9fps with two CIMs on each side and never had a problem with them over two regionals and championship. But 6061, I doubt it would have survived.
Another important thing is to make sure your key fits tightly with no backlash.
Unread 26-01-2008, 20:04
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Smile Re: pic: shaft
Looks like the key was shorter than the keyway, which would halve the load the keywayt would be able to withstand. Was that the case?
pic: Shaft Drive Bearing Blocks MAteo9944 Extra Discussion 25 01-01-2007 11:22
pic: Top View of Shaft Drive MAteo9944 Extra Discussion 2 30-12-2006 20:59
pic: The Infamous Shorn Shaft of PARC VII CD47-Bot Extra Discussion 11 12-05-2004 18:08
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
