Go to Post There is no such thing as "un-GP." - Tetraman [more]
Unread 31-01-2008, 14:13
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
Re: pic: 1251 Side Plates
Madison to answer your question about the pockets and the holes. The answer is they were machined separately to ensure the tight tolerances required on the hole layout since the whole drive train goes in between two of the plates. The plate started off square because it could be held in many vices oriented longways down the cnc machine, so the holes could be cut. Then once the holes were cut the piece was taken out of the vices and bolted on to a blank square plate using some of the existing holes to bolt the plate down so it could then be pocketed and further machined. I hope that answers your questions. The plates are pretty light but could be lighter and probably will be eventually. The majority of the plate is only 1/8in thick.
-Drew
Team 1251 The TechTigers
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
pic: 1251 teaser #2 dmellich Extra Discussion 3 18-01-2008 19:29
pic: BCR294 Protoype 4-speed transmission plates AdamHeard Extra Discussion 7 08-09-2007 21:34
pic: Banebots carrier plates problem & solution Elgin Clock Extra Discussion 14 10-03-2007 07:50
pic: 1251 Prototype v 1.2 David Guzman Extra Discussion 28 16-01-2006 12:14
pic: 1251 Teaser dmellich Extra Discussion 4 26-01-2005 16:13
