Go to Post Keep 'em cool, run it fast! - ChrisH [more]
Unread 01-02-2008, 10:43
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
pic: Team2468 Front wheel
Unread 01-02-2008, 10:45
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: pic: Team2468 Front wheel
Wow, ackerman steering, I'm looking forward to 2468's robot at Lone Star. Its great to see Austin explode with FRC teams this year!
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 01-02-2008, 10:54
MrForbes MrForbes is offline
It's not quite Ackermann steering, because the geometry is not set up quite right (notice the line from the spindle pivot to the tie rod pivot is parallel to the wheel), but it should work ok, since the wheels can't steer very far because of the frame being in the way.
Might want to see about using some smaller wheels like 4" Colsons? then it might steer more sharply.
I like the simple spindle!
Unread 01-02-2008, 10:56
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
The term Ackerman steering may be getting used a bit loosely. Ackerman steering has to do with the relationships of the pivots of the steerig linkage to provide a common turning center for all the wheel. It is a little difficult from just this picture to see if they have true Ackerman steering.
Team 2468
If you notice some tough turning or dramatic slowing occurring while turning look up Ackerman principles and try to apply them to your machine. We built up a trial chassis this way. It was nice, but I think we will go a different direction for our actual robot.
Good LucK! Make sure you drive it on carpet as it may behave very differently than on concrete.
Unread 01-02-2008, 11:13
With how short the wheelbase is on these robots, it's obvious to me that it does not have Ackermann geometry...mainly because we built one that did, and the steering arms have to be angled very far over to make it happen.
pic: Cheesy front falconmaster Extra Discussion 7 17-01-2007 15:46
pic: front view Tim566 Extra Discussion 2 24-03-2006 23:03
pic: MegaMaid front View yodameister Robot Showcase 13 11-02-2006 19:11
Front wheel steering VS. 4WD SmokeyLP Technical Discussion 26 24-01-2005 21:16
