Go to Post I'm sure an inflatable Dean Kamen action figure would be quite the sight around the home. lol - Elgin Clock [more]
Unread 03-02-2008, 01:13
Lawry Goldstein Lawry Goldstein is offline
FRC #1525
Lawry Goldstein is an unknown quantity at this point
pic: Warbots Spindle
Unread 03-02-2008, 01:14
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: pic: Warbots Spindle
I can't make out the spindle part
I'm assuming it rotates on the two bushings, but where's the spindle? Or am I just being stupid?
Unread 03-02-2008, 01:16
Never mind, I should have looked at your other picture first >.<
http://www.chiefdelphi.com/media/photos/30044?
The term spindle just confused me.
Unread 03-02-2008, 01:45
Laxphan1525's Avatar
Laxphan1525 Laxphan1525 is offline
AKA: Harrison
FRC #1525 (Warbots)
Laxphan1525 is an unknown quantity at this point
The term spindle is reference to the wheel. However i think the part name you were searching for is rack and pinion which is in reference to the mechanism that turns the robot and is pictured later. The spindles are connected to the wheels and set the robot up for a tie rod connection which could then be manipulated by the rack and pinion. We probaly could of design these to be one part however due to lack of material and four jaw chuck on the lathe we decided to test our tapping skills...
