Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Unread 04-02-2008, 14:19
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: pic: 1825s Chassis as of friday...
I love the modified Ackerman Steering, do I see a slight angle coming off the pinion? Looks like you can turn to the left better than you can turn to the right, right? If you were to drive your steering off the tierod and you have the clearance, you could probably turn equally good in both directions. I am not sure you would need to, but it might be nice to have. We planned on writting software to speed up the outside rear wheel depending on how much the front wheels turned. So far that does not appear to be necessary. Have you programed anything to compensate for the rear wheels when turning?
EDIT: What kind of turning radius do you get? I am guessing that moving the wheels in a little helps you.
pic: 1319 at Boilermaker Friday Morning Jherbie53 Extra Discussion 5 25-03-2006 17:12
pic: Top Chassis Rick TYler Robot Showcase 1 04-02-2006 19:13
pic: Woodie's Speach Friday Morning petek Extra Discussion 6 23-04-2005 22:34
pic: 195 Chassis Tom Bottiglieri Robot Showcase 14 09-02-2005 11:16
pic: Seven Chassis-es! CD47-Bot Robot Showcase 2 01-02-2004 15:03
