pic: Check out them wheels
Re: pic: Check out them wheels
Why?
tell that to 254/968... 16fps last year on < 4" wheels....
Well, with direct drive from the Toughbox and a 16" wheel, I'm calculating about 24ft/s. Maybe they plan on bouncing off the end walls to get around the track.
Is there a "custom" coupler on the back side of that wheel? It looks to me like the wheel already has a broached hub on it, which would make it quite easy to mount to. Any details? Best of luck, Bengineer |
I would be more worried about tripping breakers with a setup like that.
WOW.. Cool wheels... and they ARE big so I guess you expect to run really fast. I think the fastest I would try to control a robot in such an enclosed space as the field is 16 FPS tops. I'll have to watch video of the regional you go to. ( I think if you have wheels THAT big you also have to install airbags...)
Steve Last edited by Steve_Alaniz : 05-02-2008 at 12:24. Reason: spelling |
Oh, and Steve: L.A. typically doesn't have a webcast. The SOAP videos from last year's elims are in a format that no media player on my computer is able to read--.m4v, or something like that. |
#10
If you notice, the frame ends not too far away from the edge of the wheel. I'm guessing the robot isn't more then 24" long.
#12
| pic: Figuring out the mecanum wheels | Rapt0r9 | Extra Discussion | 4 | 25-01-2008 19:55 |
| 354 ROBOT VIDEO!!!!! NEW!!!!! MECANUM WHEELS!!! PNEUMATIC CLAW!!! CHECK IT OUT!!!! | 354.FIRST | Robot Showcase | 10 | 20-02-2007 01:41 |
| Team 245 Forums: Check them out.. | Kevin Smith | Website Design/Showcase | 1 | 27-02-2003 22:09 |
| Check this out | archiver | 2001 | 1 | 24-06-2002 01:25 |
| check out this pic... | archiver | 2000 | 2 | 23-06-2002 22:07 |
