Go to Post We always cut our parts to a tolerance of /- the width of that particular sharpie mark. - Whippet [more]
Unread 06-02-2008, 00:53
samboydh's Avatar
samboydh samboydh is offline
FRC #0702
samboydh will become famous soon enough
pic: Its almost done
Unread 06-02-2008, 00:54
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: pic: Its almost done
Will you use PVC in the final??
Unread 06-02-2008, 14:45
samboydh's Avatar
FRC #0702
ya. we are worryed about weight
Unread 06-02-2008, 14:49
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
can you get the ball out with out turning it on
Unread 06-02-2008, 14:56
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
This is basicly what we hope to do. we are going to dive fast and have the claw to hold the ball while we drive
You do know you cant be touching the ball as the robot crosses your finish line right? If the ball if in contact with your robot while crossing you dont get the 2 points for the ball, just the 2 points for the robot. It needs to have some way to let it go easily.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 06-02-2008, 15:07
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Joey
Looks to me like the whole mechanism rotates back under the power of perhaps one or two Window motors (Or Keyang, or Van Door).
Unread 06-02-2008, 16:09
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
you might want to consider something a little stronger then PVC pipe fixtures. We used some last year and it snapped like toothpicks.
Our team moved to copper fixtures this year, they don't weigh to much more and they are strong as hell.
You also have to worry about getting tangled up with other robots. It could become a large tangling hazard if it drops on top of aother robot. Says somewhere in the rules that that's not allowed. you might want to reconsider that.
FEAR THE HAWK!!!
Unread 06-02-2008, 16:54
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
maybe you guys could try thin walled (1/16"?) aluminum tubing that is round and use that?
I understand that pvc is very, very easy to build with. At any rate, good luck.
-Vivek
Unread 06-02-2008, 19:27
doukjin's Avatar
doukjin doukjin is offline
FTC 219 Mentor/Coach
AKA: Doug Kim / DJK
FTC #0219 (Wheeler Circuitrunners)
doukjin will become famous soon enoughdoukjin will become famous soon enough
Send a message via AIM to doukjin
i see you're using screws... by the looks of it
you might want to use PVC Cement to give the structure rigidity at the connecting joints without screws [might also alleviate weight]
2006 FVC Team 80 Driver
2007 FVC Team 1002 Team Manipulator Designer
GA Regional Inspire Award Winner and 2nd seeded alliance
Unread 06-02-2008, 21:41
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
While this would make it stronger, repairing the robot would be very hard. Attaching everything together with screws allows for easy switching of parts if a length of PVC breaks (which may be a recurring problem).
Unread 06-02-2008, 23:11
Bengineer
Wait, are you guys saying that we shouldn't build our robot with PVC? It's too fragile, it's too weak, it'll break? Maybe we should redesign our robot then. Oh, I'll let Bill Beatty from Team 71 know too. I think they have a couple national championship robots that used a whole lot of PVC...
When used properly, PVC is an extremely light, strong, compliant (and cheap!) material for use on a FIRST robot. I have seen a lot of PVC parts bend at some extreme angles, and return to their original shape. Aluminum parts don't seem to like such usage.
I would recommend the glueing method of attachment over the bolts.
Bengineer
Unread 06-02-2008, 23:19
EricH EricH is offline
Actually...
There is another champion who used PVC for a key part. Don't let the yellow paint on the arm of 330's 2005 robot fool you; it's PVC. And there is nothing wrong with screws; the same robot's gripper was held on with screws. See this picture. Lower right has the connections in question.
Unread 06-02-2008, 23:41
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
In my experience, thicker PVC (like that on the robots previously mentioned) is fine, but what they are using (flag-holder-esque thickness) will sometimes have issues when hit. I would reccomend the screws, if for no other reason, replacability. Also, I would have plenty of extra PVC on hand if you stick with it.
Good luck, the design looks great. How fast/controllable is it with those wheels?
Unread 07-02-2008, 02:37
doukjin's Avatar
AKA: Doug Kim / DJK
Bengineer
heh,
yes it is agreed that it is light, very strong for its weight, and cheap [and very good for prototyping], high-speed impact situations such as ones that might possibly occur in this game would not bode well for any arm made of PVC
Unread 07-02-2008, 08:12
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
How much does your robot weigh? Do you have any bumper ideas?
How long does it take for your manipulator to capture the ball? Release the ball?
Interesting drivetrain.. do all six wheels drive?
-q
Electrical Engineer Illini
pic: 1072 almost done rachal Extra Discussion 16 22-01-2008 11:35
pic: Reds Robotics Almost Done LightWaves1636 Robot Showcase 8 16-02-2007 21:23
pic: 1683 almost done sdcantrell56 Robot Showcase 4 14-02-2007 12:32
pic: Team 56 Almost Done jfischer Robot Showcase 12 18-02-2005 23:41
Pic: Team 20 almost done Ein Robot Showcase 2 16-02-2005 20:55
