Re: paper: A programming template for Autonomous Mode
Hey Team
Thanks for your answers. I set down with a C programmer Nathan and we solved the problem: 1) Added to IFI_utilities.h 2) char Limit_Mix (int); // ADDED 2/07/08 active in user_routines.c Added to user_routines_fast.c and removed from user_routines.c 3) /******************************** page 2.6 *************************************** * FUNCTION NAME: Limit_Mix * PURPOSE: Limits the mixed value for one joystick drive. * CALLED FROM: Default_Routine, this file * ARGUMENTS: * Argument Type IO Description * -------- ---- -- ----------- * intermediate_value int I * RETURNS: unsigned char ************************************************** *****************************/ unsigned char Limit_Mix (int intermediate_value) { static int limited_value; if (intermediate_value < 2000) { limited_value = 2000; } else if (intermediate_value > 2254) { limited_value = 2254; } else { limited_value = intermediate_value; } return (unsigned char) (limited_value - 2000); } 4) pwm2_tiltup = Limit_Mix(2000 + pot_08 - pot_07 + 127); 5) When we do that all of it will compile! Without lines 1, 2 above I could not make it work, but now it does thanks to GM programmer Nathan Mackarewicz! Problem I think is now solved! Thanks!! |
| A programming template for Autonomous Mode | garyk | Programming | 2 | 05-02-2008 20:08 |
| Help needed in autonomous programming for hybrid mode | Team_STORM | Programming | 3 | 21-01-2008 19:11 |
| White Paper Discuss: C Programming and Autonomous Modes for Newbies | cbolin | Extra Discussion | 3 | 09-01-2008 19:32 |
| Help for finding Autonomous Programming Template | vito3693 | VEX | 2 | 23-11-2006 19:01 |
| Programming Autonomous mode | Jared Stofflett | Programming | 3 | 11-11-2003 09:32 |
