Go to Post Like my programming class teacher has said multiple times: "Stop complaining on reddit about your code not compiling and actually fix it". - [more]
Unread 07-02-2008, 15:03
GaryVoshol's Avatar
Cogito ergo arbitro
Re: pic: Team 2404 (TNT) Omni Drive System
Wheels aside, I presume the C-channel things sticking up on all 4 sides are for bumper attachments? You would have a bolt of some form that comes out of the bumper and fits the slot on the channel, and then is tightened down.
My question is if you've checked the size of the frame. The channel adds a bit of width I think (can't tell for sure, but it looks wider than the end pieces of the kit frame). Beside that, there are bolt heads sticking out. A kit frame doesn't give you much leeway with the 28 inches - 3/8 or 5/8" as I recall. Check if you'll still fit in the box.
(since 2004)
What drive system is your team using? dpick1055 Technical Discussion 22 27-01-2007 23:29
pic: One Omni wheel drive done falconmaster Extra Discussion 2 11-01-2007 19:26
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
pic: Team 612 Drive System RoboMadi Robot Showcase 7 08-02-2006 16:38
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
