Re: pic: TEAN 540 E-BOARD 1
I think what I have done is legal, because I have done it for the past 3 years and never had anything said by the inspectors. Also that same rule was in the rules last year and i did not have to change it at competition. But i will take the stuff I need to fix it at competition. Thanks for the info.
This is from the Rule Book last year <R57> The 12V battery, the main 120-amp circuit breaker, the power distribution block, and circuit breaker distribution panels must be connected as shown in the 2007 Power Distribution Diagram. In particular: The battery must be connected to the ROBOT power system through the use of the Anderson Power Products (APP) connector. The APP connector must be attached to the battery with either the copper lugs provided in the FCI Burndy Bag or appropriate crimp-on lug connectors. The battery terminals and the connecting lugs must be insulated with shrink tubing and/or electrical tape. The main 120-amp circuit breaker must be directly connected to the hot (+) leg of the ROBOT-side APP connector. Only one 120 amp main circuit breaker is allowed. This breaker must not be bypassed. The power distribution block must be directly connected to the APP connector and main 120-amp circuit breaker. No other loads may be connected to the main 120-amp circuit breaker. All circuit breaker distribution panels must be connected directly to the power distribution block. No intermediate connections are permitted. Additional lengths of #6 red and #6 black wire may be used to reach the panels as needed to make the above connections. Circuit breakers must be accessible for inspection at each FIRST Robotics Competition event. Last edited by ERAUeagle68 : 08-02-2008 at 08:45. Reason: boled worng thing |
| pic: Team 540 Frame | ERAUeagle68 | Extra Discussion | 2 | 02-02-2008 00:00 |
| pic: Team 540 Air Cannon | Rob2713g | Extra Discussion | 5 | 22-12-2007 03:53 |
| pic: Team 540 Button Cloak | Rob2713g | Extra Discussion | 7 | 23-03-2007 07:47 |
| pic: FRC 2108, 540 | kjohnson | Extra Discussion | 26 | 13-03-2007 17:43 |
| pic: Presenting Teams 384, 540 and 1086 | Crebb | Robot Showcase | 28 | 12-03-2007 08:04 |
