Re: paper: CORDIC Trigonometric Math Library
EDIT: Ignore this post, I can not delete it
Last edited by comphappy : 09-02-2008 at 00:50. Reason: Issue turned out to be non related |
What is the advantage to using this vs a lookup table to the desired degree of accuracy?
How much more accurate and slow is the built in <math.h>? |
so id say its about... 90x faster? someone call me on this if my math is wrong. |
Ok i just found out what is needed to get this code to compile with the new 3.02 or higher compiler,
you need to replace all instances of AARGB3 with the new definition of __AARGB3 you can see the reference to this naming change here: http://ww1.microchip.com/downloads/e...03-README.html ref (27624) Last edited by comphappy : 09-02-2008 at 02:30. |
| Programming Trigonometric Functions | Dan894 | Programming | 4 | 14-02-2006 20:27 |
| Cordic functions... | Zalumaskov | Programming | 1 | 13-02-2005 00:58 |
| Trigonometric related equations | nb45ti | Math and Science | 4 | 20-07-2004 18:53 |
| White Paper Discuss: 296's CORDIC Math Library | CD47-Bot | Extra Discussion | 5 | 28-04-2004 20:01 |
| math.h library | mightywombat | Programming | 24 | 17-01-2004 13:10 |
