Go to Post I have always liked to see people get recognized for what they do, not people doing something to get recognized. - sanddrag [more]
Unread 09-02-2008, 01:11
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: paper: CORDIC Trigonometric Math Library
Originally Posted by neutrino15 View Post
What is the advantage to using this vs a lookup table to the desired degree of accuracy?
How much more accurate and slow is the built in <math.h>?
Well, the math.h implementation can be called ~100 times per second (speed test that was posted on CD at some point this month), and this function takes a half second for 4500 calls (a half second being the max time a loop can execute before the OI says it 'crashed')
so id say its about... 90x faster?
someone call me on this if my math is wrong.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 09-02-2008, 01:36
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Ok i just found out what is needed to get this code to compile with the new 3.02 or higher compiler,
you need to replace all instances of AARGB3 with the new definition of __AARGB3
you can see the reference to this naming change here:
http://ww1.microchip.com/downloads/e...03-README.html
ref (27624)
A2D Solving the Imaginary Error Function...
Programming Trigonometric Functions Dan894 Programming 4 14-02-2006 20:27
Cordic functions... Zalumaskov Programming 1 13-02-2005 00:58
Trigonometric related equations nb45ti Math and Science 4 20-07-2004 18:53
White Paper Discuss: 296's CORDIC Math Library CD47-Bot Extra Discussion 5 28-04-2004 20:01
math.h library mightywombat Programming 24 17-01-2004 13:10
