Go to Post Sleep well Chief Delphi, because for the next 6 weeks, sleep is only for the weak. :D - ttldomination [more]
Unread 10-02-2008, 22:38
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Re: pic: Team 1902- Exploding Bacon 2008 Robot
It looks really cool! I am jealous of your design. If it hurdles as well as 121 showed us it could, I'm seeing this type of bot as a powerhouse.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 10-02-2008, 22:50
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
I'm curious how influenced you were by 121's design?
Looks great, the color scheme is very nice ( not like any walrus or pig I've ever seen ;-) ).
Good Luck This Year
Chris C.
Team 151 | Alumni | 2000-2002 | Nashua High School
Team 229 | Alumni | 2003-2006 | Clarkson University
Team 148 | Alumni | 2007 | RackSolutions.com
Team 177 | Engineer | 2008-? |
Unread 11-02-2008, 08:57
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Good Luck This Year
I am not on the hardware team and was not with them on the design, but we did see 121 video before we built ours and were amazed by 121's design. We were already going that direction but I am sure 121's video did influence what the hardware team did if nothing else confirm the direction we were going.
I commend 121 for releasing the video so early. May ours work as well as theirs.
Doug Leppard
Unread 11-02-2008, 09:06
MrForbes MrForbes is offline
It is a very nice machine! Great job.
One concern that sticks out at me is the pointy ends on the claw, and the one square inch rule...you might want to think about ways to blunt the four points. One way to do this might be to move the last spacer out to the very end, or add another spacer out there.
"<R04> Protrusions from the ROBOT shall not pose hazards to GAME PIECES, team members or event staff. If, in the judgment of the inspectors or referees, a device on the ROBOT poses a hazard (particularly puncture or impalement hazards), the team will be required to remedy the situation before the ROBOT will be allowed to play. If the ROBOT includes protrusions that form the “leading edge” of the ROBOT as it drives, and are less than one square inch in surface area, it will invite detailed inspection. For example, forklifts, lifting arms, grapplers. etc. may be carefully inspected for these hazards.
Note that robot inspectors will be looking for sharp corners and edges that could cause injury, pinch points, entanglement hazards, and impaling projections. Please mitigate all such hazards. This is for the protection of team members as well as game equipment."
Unread 11-02-2008, 11:05
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Looks really good guys...I look forward to seeing it in action!
How do you plan on knocking down the ball?
FRC78: 2010-Present
FRC121: 2002-2009
Unread 11-02-2008, 11:21
Matt_Kaplan1902's Avatar
Matt_Kaplan1902 Matt_Kaplan1902 is offline
#DecadeofDelicious
Matt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond repute
Send a message via AIM to Matt_Kaplan1902
Originally Posted by wadidievrdo2u View Post
does the globe motor on your roller claw backdrive at all when you have the ball sucked in? that was a problem we had with it when we tested ours.
other than that, your bot looks awesome!
We are actually using a banebot motor on the roller, and we have not had any backdrive problems to speak of yet.
C'mon, we have to save at least one secret until we get to competition
j/k, we are still working on how exactly we are going to do that, but are pretty close to finishing.
Thanks everyone for all the compliments.
Team 1902: 2007-??, Mentor
Team 108: 2002-2005, Student
Unread 11-02-2008, 11:50
Good point. The claw is powder coated and is totally smooth, not sure about the 1 inch square rule. We will discuss this.
Doug Leppard
Unread 11-02-2008, 13:28
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
I <3 detailed inspection. We havn't popped a ball yet but I guess we could impail people, I guess we could try on some of those annoying ..... uhmm nm .. We'll take it into consideration thanks.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 11-02-2008, 13:32
I was concerned mostly from the impaling people perspective.
You have those tube spacers between the claw panels, it seems to me it would be relatively easy to just add another pair at the very end, and that would make the point into a corner.
pic: Exploding Bacon lego version dbell Extra Discussion 12 01-05-2007 15:28
Video Autonomous 1902 Exploding Bacon Doug Leppard General Forum 16 27-02-2007 12:44
paper: Exploding Bacon Chairmans wendymom Extra Discussion 4 24-02-2007 13:22
pic: 1902 Exploding Field Stephen Kowski Off-Season Events 11 11-06-2006 12:23
pic: 1902 exploding wheel Stephen Kowski Extra Discussion 12 07-05-2006 22:30
