Re: pic: Team 401 Overdrive -- Scoring Position
wow... is that monster within the 80" rule??
looks like a solid bot to me. |
you've gotta love the Hokie colors! Looks sharp.
Looking forward to seeing this in action at VCU as well. |
I was talking about when they have the arm out at 90 degrees, I tried to design an arm early on exactly like this with the dual 4-bar linkage but could never get around the 80" horizontal rule. I was wondering how they solved it?
Now you have me pondering the same thing, I guess I have another reason to look for it at VCU.
To answer the many questions,
YES...it is **Barely** within the 80" Cylinder. That was before we cut off 4" from the front of the 4-bars. Thanks for all the great comments! |
I really like your guy's air tank alignment (vertical down the center of the arm)...
very clean with the tubing and wiring on your board too <_< its a pretty robot |
When you want to lift the arm, how fast does the piston come out, because if it is too fast, wouldn't your bot tip over?
Nice clean robot. But can I ask, Why a tractor? lolz
#10
The tractor is being automated as part of a CAPSTONE senior design project with Virginia Tech Engineering Students.
The Engineering Students from VT worked with team 401 to develop what we call "farm bot" - a GPS controlled farming robot. Seems like it is an "invention" that can help a community... ...maybe it will be showing up in some animations this year ![]() |
#11
Pretty colors... one of the cooler looking frame designs I've seen in a while.
#12
Thanks ShaneP!
Team 401 likes making things look good. But ironically, the shape of the frame came from us all sitting down and optimizing the design. Each frame member has a purpose. This not only helped us to reduce weight (we are around 110lbs now with everything but lexan siding) but also made for a cool looking bot! |
| pic: Team 401 Overdrive -- Almost Done 1 | ggoldman | Extra Discussion | 2 | 10-02-2008 14:17 |
| pic: 401 FRAME TEASER - OVERDRIVE | ggoldman | Extra Discussion | 6 | 08-02-2008 06:51 |
| paper: OVERDRIVE Excel Scoring Spreadsheet | cbudrecki | Extra Discussion | 7 | 08-01-2008 00:50 |
| OVERDRIVE Rules/Scoring Questions | cbudrecki | Rules/Strategy | 64 | 07-01-2008 09:29 |
| TEAM 401: Scoring Arm Prototype - Point of View | ggoldman | Robot Showcase | 15 | 30-01-2007 16:02 |
