Go to Post FIRST has the power to change lives, inspire, and make dreams come true. - Jaine Perotti [more]
Unread 12-02-2008, 15:48
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Re: pic: Team 401 Overdrive -- Scoring Position
To answer the many questions,
YES...it is **Barely** within the 80" Cylinder. That was before we cut off 4" from the front of the 4-bars.
Thanks for all the great comments!
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 12-02-2008, 16:41
Caio's Avatar
Caio Caio is offline
Caio has a spectacular aura aboutCaio has a spectacular aura about
I really like your guy's air tank alignment (vertical down the center of the arm)...
very clean with the tubing and wiring on your board too <_< its a pretty robot
Caio Tenca
Software Engineer
Founder of Washington SWAT Robotics
Ex-Team Manager, Mech. Leader of Westview Robotics Team 1510
Team 1510 co-founder
Former Team 955 member
Curie lives on in my heart <3
Unread 12-02-2008, 16:45
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
When you want to lift the arm, how fast does the piston come out, because if it is too fast, wouldn't your bot tip over?
Unread 12-02-2008, 18:52
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Ross340 will become famous soon enoughRoss340 will become famous soon enough
Nice clean robot. But can I ask, Why a tractor? lolz
Unread 12-02-2008, 19:13
ggoldman's Avatar
FRC #0401
The tractor is being automated as part of a CAPSTONE senior design project with Virginia Tech Engineering Students.
The Engineering Students from VT worked with team 401 to develop what we call "farm bot" - a GPS controlled farming robot.
Seems like it is an "invention" that can help a community...
...maybe it will be showing up in some animations this year
Gabriel Goldman
PhD Candidate
Virginia Tech
Unread 13-02-2008, 20:05
ShaneP's Avatar
ShaneP ShaneP is offline
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
Pretty colors... one of the cooler looking frame designs I've seen in a while.
Unread 13-02-2008, 22:10
ggoldman's Avatar
FRC #0401
Thanks ShaneP!
Team 401 likes making things look good.
But ironically, the shape of the frame came from us all sitting down and optimizing the design.
Each frame member has a purpose. This not only helped us to reduce weight (we are around 110lbs now with everything but lexan siding) but also made for a cool looking bot!
Gabriel Goldman
PhD Candidate
Virginia Tech
pic: Team 401 Overdrive -- Almost Done 1 ggoldman Extra Discussion 2 10-02-2008 14:17
pic: 401 FRAME TEASER - OVERDRIVE ggoldman Extra Discussion 6 08-02-2008 06:51
paper: OVERDRIVE Excel Scoring Spreadsheet cbudrecki Extra Discussion 7 08-01-2008 00:50
OVERDRIVE Rules/Scoring Questions cbudrecki Rules/Strategy 64 07-01-2008 09:29
TEAM 401: Scoring Arm Prototype - Point of View ggoldman Robot Showcase 15 30-01-2007 16:02
