Go to Post Engineering still can't beat Physics! - Manoel [more]
Unread 13-02-2008, 20:38
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
pic: 2158 chain tensioners
Unread 13-02-2008, 20:40
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
Thumbs up Re: pic: 2158 chain tensioners
yea i hope that continuous drive train does not pop off! not quite shure how u tensioned that van door motor chain but w/e
Unread 13-02-2008, 21:22
Browzilla Browzilla is offline
Fearless Leader
AKA: David Vriezen
FRC #2530 (Team Inconceivable)
Team Role: Electrical
Browzilla is on a distinguished road
Send a message via AIM to Browzilla Send a message via MSN to Browzilla
Turnbuckles. Nice.
That looks like one awesome drivetrain.
Unread 13-02-2008, 21:23
Engineering Mentor
The van door motor is tensioned with a turn buckle....that little bracket thing between the motor shaft and the big sprocket shaft. One of the eye loops has right hand threads, the other has left hand threads, so when you turn the buckle in the middle, it moves the eye holes further apart.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 13-02-2008, 22:08
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Make sure you bring more of the shafts you use for the drive tensioner. I could see it getting bend when one wheel gets more traction than another.
-Mike
Unread 13-02-2008, 23:05
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
i recommend to going to mcmaster carr and typing in chain tensioner and picking the floating ring tensioner
R.C.
MadTown Robotics Team 1323
Unread 13-02-2008, 23:32
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
hey um... on your power sprockets it doesn't look like you have nearly enough chain on them... isn't the recommended coverage 120 degs?
or are my eyes fooling me?
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 14-02-2008, 00:32
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
looks like about 120 to me
Unread 14-02-2008, 02:20
Engineering Mentor
I've tried mcmaster's spring roller chain tensioners before and they didn't work very well.....the polyethylene wore down pretty quickly after breaking in the drivetrain, so I'd be worried about having similar problems with the floating tensioners, though I know they've been successful for others before. Plus, our solution was a little bit cheaper than buying custom tensioners
That's probably the angle that the photo was taken. Our Solidworks model says we have 117º of chain wrap around each of the drive sprockets and we haven't had any chain slip since we put the drivetrain together, so we should be good.
Unread 14-02-2008, 08:58
MrForbes MrForbes is offline
Very clever and effective....
Also the idler/tensioner on the drive chain looks like it would want to bend over sidways easily, but since the sprocket is mounted on a bearing (or at least it is free to turn on the shaft), there is very little side load on it, so it can't bend the bolts.
pic: 1281 light tensioners VEN Extra Discussion 4 10-02-2008 15:53
pic: MiniMeet - 418 & 2158 leeweek Extra Discussion 2 04-04-2007 12:32
pic: team 1029 more tensioners... bjimster1 Robot Showcase 1 11-02-2007 16:26
pic: team 1029 idlers and tensioners oooo aaaaa bjimster1 Technical Discussion 14 09-02-2007 15:33
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
