Go to Post Learn the ideas, look up the formulas. The other way round will drive you mad - Joe Johnson [more]
Unread 14-02-2008, 02:20
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: pic: 2158 chain tensioners
Originally Posted by rc_cola1323 View Post
i recommend to going to mcmaster carr and typing in chain tensioner and picking the floating ring tensioner
I've tried mcmaster's spring roller chain tensioners before and they didn't work very well.....the polyethylene wore down pretty quickly after breaking in the drivetrain, so I'd be worried about having similar problems with the floating tensioners, though I know they've been successful for others before. Plus, our solution was a little bit cheaper than buying custom tensioners
Originally Posted by Uberbots View Post
hey um... on your power sprockets it doesn't look like you have nearly enough chain on them... isn't the recommended coverage 120 degs?
or are my eyes fooling me?
That's probably the angle that the photo was taken. Our Solidworks model says we have 117º of chain wrap around each of the drive sprockets and we haven't had any chain slip since we put the drivetrain together, so we should be good.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
pic: 1281 light tensioners VEN Extra Discussion 4 10-02-2008 15:53
pic: MiniMeet - 418 & 2158 leeweek Extra Discussion 2 04-04-2007 12:32
pic: team 1029 more tensioners... bjimster1 Robot Showcase 1 11-02-2007 16:26
pic: team 1029 idlers and tensioners oooo aaaaa bjimster1 Technical Discussion 14 09-02-2007 15:33
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
