Go to Post "For once, the cake is NOT a lie." The cake claims liar's paradox. :p - JesseK [more]
Unread 19-02-2008, 16:58
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: pic: 172 almost done-ish!
Originally Posted by K.Porter View Post
The steering system (mostly made of 1/4" flat bar...that's where the weight is) isn't an ackerman system, it's what we have dubbed a "red wagon drive." Both wheels and transmissions are attatched on a "yoke" that can pivot freely around a center pin. When one wheel is commanded faster than the other, the yoke pivots up to about 30 degrees in the direction of the turn, and pulls the rest of the chassis around in a smooth turn without having to slow down.
Do you have any difficulties tracking straight? For example, lets say your right wheel is faster than the left one. If you slow the right wheel down so it's the same speed as the left one, won't you continue your arc? Or do you have code to bring your "red wagon drive" back into a alignment?
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
2200 - Done (ish) Bochek Robot Showcase 5 16-02-2008 21:52
pic: 612 Almost Done deshirider430 Extra Discussion 2 10-02-2008 18:04
pic: 1683 almost done sdcantrell56 Robot Showcase 4 14-02-2007 12:32
Team 172 - Electrical Done! K.Porter Robot Showcase 18 08-02-2007 20:44
Pic: Team 20 almost done Ein Robot Showcase 2 16-02-2005 20:55
